Blocking flight info
Message
Author
rigpiggy
#1 Post by rigpiggy » Fri Nov 11, 2016 1:10 pm
Anybody know the procedure to stop navcanada from forwarding info to 3rd party flight trackers
Ie; flightaware, flightradar24, etc.....
NotDirty!
Re: Blocking flight info
#2 Post by NotDirty! » Fri Nov 11, 2016 1:28 pm
If you just don't file flight plans, then there is nothing for them to find!
https://www.nbaa.org/ops/security/asdi/
CL-Skadoo!
#3 Post by CL-Skadoo! » Fri Nov 11, 2016 2:08 pm
rigpiggy wrote:Anybody know the procedure to stop navcanada from forwarding info to 3rd party flight trackers
Give fltplan.com a call, ask for Tina. They have great information on blocking ASDI and can point you in the right direction. Apparently it works for Canadian registrations as well. The list is published monthly, you'd want to get in touch with them and be set up before Dec. 1 or it will take an additional month to take effect. Keep in mind, your ADS-B data will still be visible to anyone with a receiver.
http://flttrack.fltplan.com/FltPlanInfo ... ocking.htm
flyinhigh
#4 Post by flyinhigh » Wed Nov 16, 2016 3:46 pm
ASDIBlock@faa.gov
Try this email address. You will be in direct contact with them. Once everything is blocked, you will be required to unblock for your fleet so you have access though.
Return to “Corporate”
