Sunwing Runway Overrun - Belfast 2017
https://www.cbc.ca/news/business/sunwin ... -1.4915969
https://www.gov.uk/aaib-reports/aircraf ... 1july-2017
Re: Sunwing Runway Overrun - Belfast 2017
So when does the PIC say shit this isn't right and either abort or push the throttles to the stops. To stagger along for 4 miles is absurd. Are they so bound by SOP's that they can't do this? What ever happened to feeling what the airplane is doing? Never flown that size of aircraft but I would think Captains should realize what's normal and what's not.
“The crew did not apply full thrust until the aircraft was approximately 4 km from the end of the runway, at around 800 ft aal.”
Huh?
Huh?
- JetSetter87
Fully agree here..... How bound are you by a power setting....If it dosent feel right firewall that b**** right away!!!! Clearly these guys don't pay attention to the runway length required after they enter the data in the FMS.....MUSKEG wrote: ↑Thu Nov 22, 2018 3:57 pm So when does the PIC say shit this isn't right and either abort or push the throttles to the stops. To stagger along for 4 miles is absurd. Are they so bound by SOP's that they can't do this? What ever happened to feeling what the airplane is doing? Never flown that size of aircraft but I would think Captains should realize what's normal and what's not.
- rookiepilot
Pressing TOGA without firewalling does nothing... EECs still bound by erroneous OAT inputs into the FMC. Just moves the carets
Autothrottle might be bound by FMC inputs but manually advancing thrust levers on a Boeing gives more thrust.
EDIT - This is what EECs protect. - EDIT
No mention of erroneous OAT inputs into the FMC. Your reference for such would be appreciated.
Full AAR report High res
https://assets.publishing.service.gov.u ... Hi_Res.pdf
Here's what pisses me off ... How could you not know, that the N1 calculated from the FMS was completely erroneous. It's a 9100' runway so depending on the environmental factors and weights (report suggest 71.9 tons) you'd maybe get a 91-93% N1 with a assumed temperature derate.
Now bring the OAT down to -52 and the FMS spits you out something like 80-82% N1 and it's bugged and it's what the EEC/AT will command and hold.
At this point, how can you not know that this is garbage right there? How little do you know about your own AC's performance that you don't immediately have red flags popping up. From the report, it seems like a well experienced crew so you'd think they would have questioned the data and notice the sluggish takeoff run and climb performance ... I don't operate the NG but I'd love to know from experienced crews here; how often do you takeoff at 81.5% N1 ?
How would the runway length required significantly be affected by the temperature? Isn't the whole point that the computer is smart enough to calculate the required power setting based on the maximum available field length?JetSetter87 wrote: ↑Thu Nov 22, 2018 5:18 pmFully agree here..... How bound are you by a power setting....If it dosent feel right firewall that b**** right away!!!! Clearly these guys don't pay attention to the runway length required after they enter the data in the FMS.....MUSKEG wrote: ↑Thu Nov 22, 2018 3:57 pm So when does the PIC say shit this isn't right and either abort or push the throttles to the stops. To stagger along for 4 miles is absurd. Are they so bound by SOP's that they can't do this? What ever happened to feeling what the airplane is doing? Never flown that size of aircraft but I would think Captains should realize what's normal and what's not.
In this accident, there were other factors involved, but the crew, despite noticing improper acceleration, long take off run, stall warning, inability to climb and impending crash, never fire-walled the engines.
https://en.wikipedia.org/wiki/Air_Florida_Flight_90
I might think harder about this in the future, but I can honestly say an 81% N1 takeoff thrust setting wouldn’t seem out of line to me on a quick glance.
I fly with CFM engines (different aircraft type and -5 engines) and that would certainly seem too low to me. We don't even see 81% in cruise!
I have many concerns on this crew and company SOPs...
#1- How can you enter -52C (which requires an extra entry of the minus sign) in the FMC when the actual OAT is +16C? That's a whopping 68C difference!
#2- When initializing their FMCs for the takeoff performance and you enter the numbers (winds, temperature and others), don't their SOPs ask to cross check each other and the numbers entered?
#3- Back to the perf section of the FMC, wouldn't a very low N1 or EPR setting not sound a bell to you?
#4- Again, back to the perf section of the FMC, after the inputs are in, you should get a runway length needed for your takeoff run, so if this number on that day with the perfs they initialised was for argument's sake 4000', wouldn't you ask yourself questions as you are rolling down the runway past the 4000 foot mark and you were no where close to your speeds or already rotating?
#4 is the one that is most astounding.
I’ve seen below 80% more than a few times, albeit for some pretty light takeoffs.Eric Janson wrote: ↑Fri Nov 23, 2018 10:16 amI fly with CFM engines (different aircraft type and -5 engines) and that would certainly seem too low to me. We don't even see 81% in cruise!
Correct, I mixed the two up, fixed.
- complexintentions
But I thought only Asian carriers had runway excursions. At least, that's what I read on another thread!
This wasn’t a runway excursion, it was an impromptu extension.
Seriously though, there’s plenty of things to look at that should tell you things are not right. Don’t assume the FMS AP/AT is going to do it all for you.
