Use The Park Brake
Re: Use The Park Brake
pelmet wrote: Sun Nov 01, 2020 12:18 pm
challenger_nami wrote: Sun Nov 01, 2020 12:02 pm Here is @Photofly and his logic ... or lack of IT.
There are times where the discussion becomes obscure or unrelated stuff such as ....
Cliff Jumper wrote: Fri Oct 30, 2020 4:48 pm Use the parking brake when?
Every time you stop?
Or only those times where you intended to be completely fixated?
photofly wrote: Sun Nov 01, 2020 11:16 am Do you use wheel chocks? If so, why not use the parking brake instead? It would save all that messing about with bits of wood or triangular bits of rubber.
When the engine is running, use the park brake when dealing with necessary distractions for any significant amount of time(unless it is realistically considered to be unreliable in which case an alternative safe plan should be used).
I don't think a checklist is adequate here. I'm seeing a flowchart.
pelmet wrote: Sun Nov 01, 2020 12:18 pm When the engine is running, use the park brake when dealing with necessary distractions for any significant amount of time(unless it is realistically considered to be unreliable in which case an alternative safe plan should be used).
How do you know if it's reliable or not? You could assume, in which case if it slips, you'll end up like the pilot in the first post, and if you assume it's not reliable, then it's not to be trusted, and you should keep your eyes outside and your feet on the brake pedals.
I mean either you trust it 100% in which case if it fails and you roll into another airplane it wasn't your fault, like having an engine failure, no need to feel bad, or you don't trust it 100%, in which case, you have to keep your eyes outside regardless, and the brake isn't worth using. I just don't see a middle ground here.
I really don't see how you can ever take your eyes off the outside, with a whirling six or seven foot bar of aluminium going round five feet in front of you. Parking brakes, pedals, or even if the plane is tied down. If you really can't keep track of what's around you, I think you should shut the engine down.
rookiepilot wrote: Sun Nov 01, 2020 12:32 pm I don't think a checklist is adequate here. I'm seeing a flowchart.
I"m tempted to say that the Almighty put you on earth to make this post. Thank you.
challenger_nami wrote: Sun Nov 01, 2020 12:23 pm @Pelmet
Exactly. My experience has been the same. and sadly, it’s usually the same individuals who come up with preposterous arguments to prove that the original poster’s safety suggestion was somehow invalid.
It’s difficult, if not impossible to win against ignorance, arrogance and dumbness... my strategy/suggestion is to NOT even engage/respond to these individuals when they come up with their BS, just to shut you down.
Nobody wants to shut pelmet down. He posts interesting stuff. Sometimes other people - me included - don't agree with him. That's ok too.
photofly wrote: Sun Nov 01, 2020 2:12 pm Nobody wants to shut pelmet down. He posts interesting stuff. Sometimes other people - me included - don't agree with him. That's ok too.
Helpful tool for single engine Cessna ops?
Per your request. Sample.....
https://vizworld.com/2010/09/pentagons- ... low-chart/
Unfortunately, we have people, grown adults who seem to be more interested in shutting down, making silly statements repeatedly, etc in order to harass.
One need only look at the intelligent responses versus the other type.
Here is an example of someone who disagrees that has an intelligent response....
Big Pistons Forever wrote: Fri Oct 30, 2020 8:51 pm The single engine Cessna's have a mechanical part brake. When you pull the handle you are pulling a cable which mechanically holds the deflected pedal down. The problem is sometimes the the brake won't fully release because the cable binds. I have had this happen enough times I never use the park brake and discourage my students not to either. Also if not properly rigged you can have one brake only partial engage.
I think pilots can walk and chew gum at the same time and so they should be able to hold the toe brakes with their feet and do other things. Even if the park brake worked perfectly the airplane can still slide if the surface is slippery so for that reason I always emphasized the need to limit head down time and come back to heads up frequently to keep SA
Finally I noted one poster said he was head down selecting one tank instead of just leaving the selector on both. Personally I think this FTU-ism is silly. No Cessna POH requires this "check" and there AFAIK never been a case where a high wing Cessna ever spontaneously stopped feeding fuel from one tank. The only time this scenario has happened was immediately after the fuel system had been disturbed, usually because of a wing removal and reinstallation. So yes immediately after this kind o major maintenance you should run the engine at runup RPM for several minutes on each tank to ensure everything got reconnected. After that follow the POH which specifies both tanks for start and run-up and recheck both for the pretakeoff check
In any case this check on any fuel injected Cessna single is completely pointless.
If you want to fuss about fuel selectors then check the fuel on off valve on Cessna C 150 and C 152's. I would say in probably half of the C 150's I have seen this valve is frozen in the on position. making it impossible to turn off the fuel in the event of a fire.
Here is the other type....
rookiepilot wrote: Sun Nov 01, 2020 2:22 pm Helpful tool for single engine Cessna ops?
and
rookiepilot wrote: Sun Nov 01, 2020 8:41 am Not feeding this.......starve it of oxygen.
There appears to be deeper issues that have been admitted to on this forum. I suggest, leaving temporarily to deal with your issues instead of bringing them here. I would rather make posts about safety and have discussion similar to what BPF posted.
pelmet wrote: Sun Nov 01, 2020 2:32 pm
and
Gee. Didn't you just come off a one month holiday for not making nice with other posters?
Want to talk about what you have learned from that?
We are here to listen.
I really hope it's more than another checklist. :D
pelmet wrote: Sun Nov 01, 2020 2:32 pm Here is the other type....
Everyone has a tendency to be intolerant of humour when it comes from someone who disagrees with us.
rookiepilot wrote: Sun Nov 01, 2020 2:38 pm
and
Start another thread about it if you like to keep this one focused on why the parking brake should be used if you can't pay attention outside and have to take your feet off the brakes.
Aviatard
Post by Aviatard »
So should we use the parking brake or what?
Aviatard wrote: Sun Nov 01, 2020 5:51 pm So should we use the parking brake or what?
One can see where the idea that they are not reliable can come from.
"a. Parking brakes are not reliable"
https://www.bramptonflightcentre.com/wp ... Manual.pdf
My experience. They have worked reliably every time I have used them on modern Cessna 172 aircraft.
pelmet wrote: Sun Nov 01, 2020 6:34 pm
That's nice they've worked for you. You've said this repeatedly.
Do you expect everyone else to change their mind, and their procedures, based on one anonymous poster on this issue, compared to well known and documented information -- like this manual and multiple flight instructors posting - presumably with a ton of Cessna time -- with many decades of experience?
I'm unsure what your goal is here.
Are you advising flight schools to change their ops manual?
rookiepilot wrote: Sun Nov 01, 2020 6:54 pm
I am advising pilots of light aircraft that when the engine is running, use the park brake when dealing with necessary distractions for any significant amount of time(unless it is realistically considered to be unreliable in which case an alternative safe plan should be used).
photofly wrote: Sun Nov 01, 2020 1:11 pm
As the world goes around In circles....
rookiepilot wrote: Fri Oct 30, 2020 9:54 am
My AME doesn't like using them. No instructor I've had in the past liked using them -- on Cessna singles anyway.
Perhaps they are all foolish, but I rate their in person advice rather above the internet on what is wise or not.
youhavecontrol wrote: Fri Oct 30, 2020 7:58 pm I don't fault someone for wanting to adjust the seat prior to taxi with the engine running. I've done that many times. Sometimes you think you have the seat set how you like it, only to realize you want to tweak it just so once you start looking around to taxi. Nothing wrong with that, and it certainly doesn't mean the pilot wasn't prepared. I'm 6'4" and it takes me time to get adjusted exactly how I like in small aircraft. Often I have to re-adjust once the aircraft warms up and I take my jacket off, meaning I take my seat belt off, slide the seat a bit and remove my jacked, all with the engine running. Does nobody else have to do this? I most definitely use the park brake while I do it because keeping my feet on the brakes the entire time is tricky. This doesn't mean I'm unaware of what's going on outside... but I still rely on the park brake to hold the aircraft for the moment.
I agree the with the OP that the park brake should have been set, and on most aircraft it's quite reasonable to expect the park brake pressure to hold for the 10 seconds or less it takes to prop yourself up to shift your seat (which you can't do with your feet on the brakes in most aircraft I've flown). I agree that he should have been glancing outside as much as able, but at the same time if you can't trust the brake pressure to hold for 10 seconds, your plane is probably a piece of crap to begin with and you shouldn't fly it.
The whole park brake discussion about do/don't is so strange to me. It's like debating over the use of sunglasses. Is it sunny? ..sure use them, but wait! What if it's night, then it's harder to see?!?! But if the sun is burning your eyes... yeah, it's probably good to use them.
There's a time and place for this stuff and a certain level of awareness required in everything we do. I trust autopilot enough to read some SOP's during cruise, but it doesn't mean I'm going to take a nap.
RedAndWhiteBaron wrote: Fri Oct 30, 2020 2:57 pm And I respectfully disagree. Although I agree that you must not remove peripheral attention from outside the aircraft, I am pragmatic enough to recognize that mistakes happen.
As has been said above, had that pilot used the parking brake, this thread would not exist. I think that makes it very relevant to the discussion. Pilot inattention and use of the parking brake are separate, but connected issues here. The latter is a safety mechanism in case the former fails (and sooner or later, no matter how good you are, it will - most of us are just lucky when it happens).
As the world goes around in circles.....
