WestJet almost puts one in the drink
Re: WestJet almost puts one in the drink
Cliff Jumper wrote: Sun Jun 17, 2018 7:56 am
digits_ wrote: Sat Jun 16, 2018 7:23 pm You can easily check that yourself.
So, you're suggesting that this is soooo obvious that it is common sense and doesn't need to be written down anywhere?
There are quite a few (thousand) books on flight crew illusions, I just can't remember this in any of them. But, I fully admit, I might have missed it.
I wrote out the whole procedure how you can check it out yourself. Any pilot should be able to follow it. So yes, easy to verify if it is accurate.
I never said it was obvious. It is one of those things that usually don't matter.
If you disagree, let me know at which step it fails or where the error is.
Eric Janson
Post by Eric Janson »
@digits_
Semantics maybe - but in reduced visibility you have marginal to no depth perception. You cannot accurately determine height and distance. This is why PAPI/Approach Lights/DME was invented.
@Cliff Jumper
Optical illusions discussed here - shortened horizon distance is mentioned.
https://www.skybrary.aero/bookshelf/books/812.pdf
The ALAR toolkit is worth downloading as it has a great deal of useful information
Cliff Jumper
Post by Cliff Jumper »
Bit Eric, that reference gives the exact opposite of what you are saying. It says that in haze, you could interpret being too low, and pull up.
Eric Janson
Page 4 - Flight Path Monitoring.
Cliff Jumper
Still can't find the part where it says 'reduced visibility causes the illusion of increased pitch'.
But, granted, I don't read good.
Eric Janson
Final report released.
http://www.bst-tsb.gc.ca/eng/rapports-r ... 7f0052.pdf
Lowest recorded altitude 39 feet! :shock: :shock:
Someone should send Lauren Stewart a copy of the report.
98 Corolla
Post by 98 Corolla »
39 feet from what point on the aircraft?
Heliian
Post by Heliian »
98 Corolla wrote: Fri Aug 24, 2018 12:29 pm 39 feet from what point on the aircraft?
Wherever the source for the egpws comes from. I would guess a rad alt on the bottom of the fuselage.
That was an overly detailed report, they really pushed the paper well. No FDR data to go on either.
J31
Post by J31 »
Eric Janson wrote: Fri Aug 24, 2018 12:13 pm Final report released.
That is the report that was released on June 4 2018 and Donald posted it that day. Eric we already hashed it out! :wink:
Big deal. AC wins that contest.
Eric Janson
J31 wrote: Fri Aug 24, 2018 3:04 pm
Ok thanks - I missed that.
Zaibatsu
Post by Zaibatsu »
rookiepilot wrote: Fri Aug 24, 2018 3:24 pm
At night
Still on the vertical profile
On an offset lateral profile where lights were misleading
Nobody got a picture of that
C.W.E.
Post by C.W.E. »
I can understand that part of the problem the crew had in SFO because there are not many runways with airplanes on it pointed towards you with all those bright lights blinding you.
PostmasterGeneral
Post by PostmasterGeneral »
That brings up an interesting topic; the use of the taxi-light while holding short?
I always have it on anytime I’m away from the apron, provided it isn’t pointed directly AT another aircraft. Even when not in motion, I’ll generally leave it on unless giving way to another aircraft.
They’re usually aimed low enough that it won’t “blind” anyone else. What’s everyone else’s opinion on this? Looks like in the AC incident it helped a bit.
J31
Post by J31 »
A lot of airline SOP's have the taxi light on when ever moving under power day and night.
