Light aircraft down near Gatineau
Message
Author
#1 Post by rookiepilot » Sat Oct 21, 2017 3:29 pm
AirFrame
Re: Light aircraft down near Gatineau
#2 Post by AirFrame » Sat Oct 21, 2017 4:18 pm
Wow, it threw the tailwheel all the way forward to the nose of the airplane!
cgzro
#3 Post by cgzro » Sat Oct 21, 2017 6:12 pm
Thank goodness nobody was hurt. He was very calm on the radio talking to Gatineau as it unfolded.
#4 Post by pelmet » Sun Nov 19, 2017 7:42 pm
"C-FMSM, un Maule (MT-7-235) en exploitation privée, effectuait un vol local selon les règles de vol à vue depuis Ottawa/Gatineau, QC (CYND) avec 1 pilote et 1 passager à bord. Alors que l’appareil se trouvait à environ 4 miles marins au nord-ouest de CYND, il a subi une panne moteur (Avco
Lycoming, IO-540-W1A5). Le pilote a déclaré un état d’urgence et a effectué un atterrissage forcé dans un champ. L’appareil a capoté et subit des dommages importants. Il n’y a eu aucun blessé. Le Centre conjoint de coordination des opérations de sauvetage a reçu le signal de l’émetteur de
localisation d'urgence."
Google Translate.....
"C-FMSM, a privately operated Maule (MT-7-235), was on a local flight under visual flight rules from Ottawa / Gatineau, QC (CYND) with 1 pilot and 1 passenger on board. 4 nautical miles northwest of CYND, engine failure (Avco Lycoming, IO-540-W1A5). The pilot declared a state of emergency and made a forced landing in a field. The unit has been overturned and is severely damaged. There were no injuries. The Joint Rescue Coordination Center received the signal from the emergency localization. "
Redneck_pilot86
#5 Post by Redneck_pilot86 » Fri Nov 24, 2017 10:52 pm
The T in MT-7-235 denotes tricycle gear.
AirFrame
#6 Post by AirFrame » Sat Nov 25, 2017 8:32 am
Sorry, apparently I forgot the smiley-face to make it completely obvious that I was joking.
CpnCrunch
#7 Post by CpnCrunch » Sat Nov 25, 2017 9:41 am
Another Maule with an IO-540 had an engine failure this week at Langley:
http://wwwapps.tc.gc.ca/Saf-Sec-Sur/2/c ... d2017P2203
