pdw wrote: ↑Mon Nov 06, 2017 9:30 am
The answer to earlier/similar questioning about doing that is "No". Not done.
No need to practise if an examiner isn't going there / doing one of those down too low.
_______________
Another Q:
If one fails just as gear starts going in / selected UP after rotation, what is the added speed interruption (just for that power draw) under the remaining engine's power as the other
feathers?
Just because "its not done" doesn't mean it wasn't.
The Seneca II has an electric hydraulic pump for the landing gear. No appreciable load on the engine/s
It has half decent single engine performance as well.
It is an easy plane to over-boost. My only other thought is if one engine suffered a mechanical failure and in the panic full throttle applied to the functioning engine causing induction system failure or piston damage of some sort taking out the other engine.
-There seems to have been fuel based on the post crash fire.
-They asked for a circuit, not stating a problem or declaring an emergency, (suggesting perhaps a practice manoeuvre)
-The airplane bank over and dove straight in, classic below vmc outcome.
I've flown a Seneca II a number of times and have found it to be a well behaved and decent performing twin. Only downside to it in my mind is the weight of the controls, feels like driving a cement truck without power steering, not a big deal, just not comparable to some of its more refined contemporaries. Though the de icing and counter rotating engines are appreciated.
Finally, condolences to the families.
