Crash video. Performance over 50 foot Obstacle not Calculated
Post by pelmet » Fri Feb 16, 2018 11:57 am
Pratt X 3
Re: Crash video. Performance over 50 foot Obstacle not Calculated
Post by Pratt X 3 » Fri Feb 16, 2018 12:55 pm
Brought to you by the same marketing genius' that came up with Icon's advertising campaign?
https://www.flyskyrunner.com/
Have Pratts - Will Travel
Heliian
Post by Heliian » Fri Feb 16, 2018 2:36 pm
Specs say a takeoff distance of 450 ft. It looked like it was flying but then sank.
The whole thing looks like a bad idea.
Schooner69A
Post by Schooner69A » Fri Feb 16, 2018 2:49 pm
SKYRUNNER: A solution for which no problem exists... (;>0)
SuperchargedRS
Post by SuperchargedRS » Fri Feb 16, 2018 3:37 pm
I get it, it's a pretty good idea for some areas, could see that idea being good in baja, some places in FL or CA, but the big issue for me would be it seems way underpowered, and it's like 120,000USD.
With another 50hp and a 15-maybe 20k price tag, sure, that'd beat a quad in some settings for sure.
Post by rookiepilot » Fri Feb 16, 2018 4:10 pm
Couldn't pay me to ride in that death trap.
Jet Jockey
Post by Jet Jockey » Fri Feb 16, 2018 7:41 pm
WOW! Simply WOW!
Hope they recuperate and live a normal life after that crash.
mantogasrsrwy
Post by mantogasrsrwy » Sat Feb 17, 2018 7:59 am
Do you think that guy who stopped filming and turned his back on the crash was kicking himself?
mbav8r
Post by mbav8r » Sat Feb 17, 2018 8:03 am
I have to say and really hate to admit it but this might be a case for PDWs wind demons!
The roll cage on that thing looked pretty robust, so hopefully just some bumps and bruises, has anyone seen information on injuries?
marlin
Post by marlin » Sat Feb 17, 2018 10:40 am
Video description says both on board were severely injured, but alive. I hope they recover as well, hitting a building and then falling off of it... Yikes.
pdw
Post by pdw » Sat Feb 17, 2018 10:55 am
That's awful.
"Mantogas", the cameraman with his back turned was spared watching that in real time.
Considering mbav8r, the takeoff would likely be upwind as per normal practice; yet nearing the distant building on its lee side they are still so low .. then all at once can't compensate for what appears to be a drop in lift, the lee-effect of the "Obstacle". At first still appears will easily clear (as the cameraman turns around), just at the point of an obvious downdraft tendency / unexpected and unplanned sink rate. (especially for this heavier equipment) Perhaps the smaller losses of relativewind might also be a lot BIGGER, right where the usual anticipated increases with height are being relied upon ?
Needs date & time and location.
Post by rookiepilot » Sat Feb 17, 2018 1:51 pm
.....and maybe the thing has a scary 50 FPM climb rate, heavy, didn't use whole runway.....anyway....hope for full recovery
RatherBeFlying
Post by RatherBeFlying » Sat Feb 17, 2018 4:14 pm
The Wright brothers before their first flight had worked out directional control - something that appears to have escaped the attention of the "designers" of this contraption.
GyvAir
Post by GyvAir » Sat Feb 17, 2018 7:48 pm
Helmets? Why would you want to wear helmets in an airborne ATV?
Apparently happened in Dubai on February 9th, 2018 at 10:15am local time.
Supposed to be a hangar that they collided with. Windsock at 0:44?
Looking at the canopy trailing edge, it looks like they were trying to roll, from the the moment they got light on the wheels, right up to point of impact. I think a lot of what appears to be sink rate is actually illusion cause by them being blown rapidly to the left, once they'd gained a little altitude, entering the higher wind speeds, aloft.
How much climb performance is sacrificed in a powered parachute when trying to roll?
