Fly Jamaica Boeing 757 overrun
J31
Post by J31 »
About 11 minutes into the flight, the pilot indicated the Boeing 757 was experiencing problems with its hydraulic system, Guyana officials said at a Friday morning news conference. The aircraft returned to Cheddi Jagan, where it crash landed, leaving the runway.
https://www.cbc.ca/news/canada/toronto/ ... -1.4898633
GyvAir
Re: Fly Jamaica Boeing 757 overrun
Post by GyvAir »
The plane eventually rolled to a stop after a spiked rumble strip laid across the runway by an airport ground crew punctured several tires on its right side.
GyvAir wrote: Fri Nov 09, 2018 10:39 pm
Thinking outside of the box. They use it in the movies on cars, so it is obviously an accepted aviation procedure as well!
Eric Janson
Post by Eric Janson »
Something doesn't add up.
A loss of a hydraulic system shouldn't lead to an overrun - especially not on a 10500' runway.
Jet Jockey
Post by Jet Jockey »
Eric Janson wrote: Sat Nov 10, 2018 2:30 am Something doesn't add up.
Don't know the nature of the hydraulic failure(s) at this point but...
What if he had no reversers and only partial braking, then no braking?
Eric Janson
Jet Jockey wrote: Sat Nov 10, 2018 6:08 am
3 Hydraulic systems. Normal, Alternate and Reserve Brakes. Plenty of redundancy.
757 is an extremely capable aircraft. Landing speeds are lower than a 737.
