Air Canada tailstrike in Hong Kong
LennyLeonard
Re: Air Canada tailstrike in Hong Kong
Post by LennyLeonard »
What happens to the FO in this case? I would imagine he hasn't flown since and will probably be retrained, if he has not already been done so?
C.W.E.
Post by C.W.E. »
If it was the FO flying where was the Captain?
Eric Janson
Post by Eric Janson »
Inverted2 wrote: Sat Jan 12, 2019 6:57 pm Doesn't list the first officers experience. Could be a 2000 hr wonder new hire but who knows. Strange they touched down on the right main gear first with a left hand crosswind. Not the way I was taught to do crosswind landings.
I don't fly the 777 but I understand it is quite sensitive in roll.
The preliminary report sounds like this was a case of PIO (Pilot Induced Oscillation).
For those not familiar with PIO it looks like this:-
https://www.youtube.com/watch?v=02ddnGzxNZs
No mention of windshear.
the aircraft entered into series of minor lateral roll deviations followed by a pronounced roll first to the left and then to the right,
What caused the pronounced roll left and right that the pilot needed large inputs to attempt to correct for?
Inverted2 wrote: Sat Jan 12, 2019 6:57 pm Strange they touched down on the right main gear first with a left hand crosswind. Not the way I was taught to do crosswind landings.
Probable not what was planned in terms of touchdown attitude.
Eric Janson wrote: Sat Jan 12, 2019 11:08 pm I don't fly the 777 but I understand it is quite sensitive in roll.
The approach in the video was in quite turbulent conditions leading to required counteracting control inputs. The turbulence encountered in HKG is unknown but could easily have been significantly less.
sportingrifle
Post by sportingrifle »
Eric...
The 777 is not sensitive in roll, or any other axis for that matter. It is a beast compared to the 330. But what it does have is a lot of roll inertia. Once you get all that mass rolling, it wants to keep rolling. The other thing is that the flare is less pronounced than with most other types. On all my first trips in a new airplane, the training captain always did the first one, just so I could see what the world should look like. Especially with a runway change and a gusty day. Expensive lesson but that is how we all learn.
Cheers Sportingrifle.
Puffpuffpass
Post by Puffpuffpass »
Eric Janson
@sportingrifle
Thanks for the 777 info. I'm just curious whether the fly-by-wire system corrects a wing drop in a similar manner to the airbus fly-by-wire. Very easy to get into a PIO situation in gusty conditions with the airbus.
Have Boeing changed from the "Manual Flight - Manual Thrust" philosophy? When I flew Boeing we only used autothrust during an autoland.
One thing I don't understand is why the FO was flying.
As has been correctly stated Hong Kong is a tricky airport and perhaps not the best choice for the first flight as PF on a new Type.
I've flown for several companies where new FO were initially only allowed to land at home base. Then as they gained experience with the aircraft/airports/conditions they would be allowed to land at out stations. Sensible policy.
Here's another line training event (new Capt) in conditions that were unsuitable for training imho.
https://www.youtube.com/watch?v=mVrn-TMtRjA
sportingrifle
Eric...
Unfortunately the Boeing manuals, including the more comprehensive Cathay one that I pirated, do not explain the control laws in any detail the way the Airbus ones do. I have never read anything that makes me think that the airplane attempts to damp roll oscillations or maintain 1 "G" the way the Airbus does. And it doesn't seem to fly like it does either.
Regarding your comments about initial line experience. I can't really comment other than to say all good points.
Cheers sportingrifle
Post by ahramin »
My understanding is 777 FBW is speed stable, not G stable.
sportingrifle
Yes it is.
telex
Post by telex »
Puffpuffpass wrote: Mon Jan 14, 2019 11:54 am It seriously cracks me up with all you guys talking about this crew as if they are 2000 hr wonders....before you post, how about you state what experience you have and what you are basing your opinion on.
HKG can be a sneaky bitch of an airport, the winds were in the perfect direction for wind shear, although the velocity wasn't where it should have been, anyone who has flown in here will back me up in how quickly things can change. As for proper X-wind technique, LOL anyone want to take a guess in how much a GE90-115BL cost? Let me give you a ball park, over the 40 million mark. Not really in the mood to bounce one of those off the ground. This is not the type of plane you give a foot full of rudder and slip it on, yes it can very well do that, in smooth consistent winds, in gusty variable conditions the proper procedure is to have a bit of crab on touch down, have the mains hit the centreline, while the cockpit is off to the left or right, it takes some getting used to, The gear is designed to crab on touch down for this reason.
As for what happened, who knows, its a hell of a long day, you feel like shit at this point and more then a little slow, it doesn't take much for something to change and it bite you in the ass.
The Skipper and F/O have been around for years, although the F/O was on a training flight. They both were more then qualified to be in those seats, much more qualified then the majority commenting here.
You guys talk like they should have hand bombed it in from 20 Grand....this ain't Northern Ontario.
Do you and rockie share a user name? Must protect the mothership at all costs...
12 knot crosswind on landing. Yeah it's a bitch I know. The profession is truly dead after this near death experience only averted by qualified crew members sacrificing an airframe and saving the $40 million engines. Heroes I tell you.
Two relief pilots onboard and still blame the duty day? Or did you blame the $40 million engine you wanted to protect? What dollar value comparison are you placing on the tail strike vs a pod strike? Surely the $40 million engine would not have been lost? How long has the airframe been out of service now? Does a grounded airframe get relief on insurance and lease costs?
Or was it the runway change which was to blame for the tail strike? Yes a bitch indeed. "Official cause of tail strike was found to be runway change". Maybe you can direct me to the reports which blames runway change for tail strikes? This event has resulted in substantial aircraft damage. ppp I'm sorry to tell you but that is an accident by definition.
How about the PF who was inexperienced on type WHO WAS CONDUCTING HIS OR HER FIRST LANDING ON TYPE over controlling the aircraft as a contributing factor?
The initial report mentions the Captain's experience. But not the FO's experience. Curious why such a qualified crew member would not have his/her experience noted.
But you mention the FO was more than qualified. But then offer the escape clause mentioning a training flight. So not qualified. Or sort of qualified. Or qualified in other areas but not qualified in this particular landing as HK is a bitch that can bite you in the ass. Or some shit.
I don't fault the Captain. Start the day off right. Nice to meet you. Which way do you want to fly?
Some days it's better to say I will take us there. You will take us back. Hopefully the candidate picks up a few things right from the get go.
Other days the Captain tests you from the day you get on the bus.
Now you need my quals to justify my comments?
Back to you ppp.
How many airplanes land per year in HK?
It was just this particular bitch of a 12 knot crosswind protecting $40 million dollar engines with a runway change that caused this particular event with an airframe that had a maple leaf on the tail?
Probably best at this point in the discussion to wait for the final report. It will be interesting to see if there were significantly stronger winds out of the north at low altitude. If I remember correctly, there is a caution about Low Level Jets(wind that is) during the winter. Something that could cause a shear. There can be some interesting wind patterns in some of these locations. Anchorage is pretty much the most bizarre that I have seen.
Perhaps other factors were involved that had little or mothing to do with the winds or a shear but it has been brought up as a possibility and is a good reminder that one should never assume that the surface wind is similar to the wind at a couple of hundred feet without some sort of corroboration, especially in mountainous terrain. Fortunately, modern Boeing's have a wind vector displayed which can be very helpful making it easier to anticipate sudden wind changes, although it is surprising how often the big wind change happens smoothly, potentially lulling one into complacency.
C.W.E.
Post by C.W.E. »
I guess it was just another Air Canada " Hard landing "
But this time it was on the runway not before it.
LETUN
Post by LETUN »
Agree with Telex, the 777 is easy to fly and nothing special about the airport and WX, the WS note in the Jepp is a red herring in this case. And as he said, first landing in a WB should have been done by the captain so that the trainee gets the "picture".
For whatever reason, people new to the 777 have a tendency to over control the ailerons, creating PIO. People coming from the 737s being the worst offenders. A good demonstration is to tell the fo to let go of the yoke for a moment; magically the approach becomes smooth. The 777 is super stable with 3-4 ft tail clearance on landing (16" on take-off).
Also agree with the comments about the treatment of AC's accidents/incidents from some posters. Change the livery for that of your favorite asian carrier or AF and this site would be on fire asking for overflight bans.
LETUN
Post by LETUN »
C-FITW has returned to the line according to FR24 data.
Took 2 months to fix
LETUN wrote: Tue Jan 15, 2019 5:39 pm
LOL -- home gamer bias always....
Curious how many landings Cathay does in HKG a year, one of those super "dangerous" Asian carriers.....and how many accidents again? :mrgreen:
BMLtech
Post by BMLtech »
The report is out.
https://www.thb.gov.hk/aaia/doc/Air%20C ... 0Dec21.pdf
For the fatigue caused another incident crowd....the pilots reported that they felt fine. 4 pilots on this flight.
For the windshear crowd.......there was a windshear alert of -25 knots to ATC about 12 minutes before the incident. However, the report states that the flights right before and after the incident flight reported no issues and that the FDR analysis showed a steady airspeed. Interpret as you like.
For the inexperienced pilot crowd....the pilot has plenty of hours. No mention of piloting ability in the report though(an AC insider would have to give us that).
According to the report, this incident was caused by PIO. The F/O adding more and more back and forth aileron inputs in the final couple of hundred feet. In fact, so much aileron input that he/she was going stop to stop with increasingly rapid inputs. Not quite sure how that sort of thing happens on any airliner in relatively smooth air. And the pilot had flown quite a few types.
Then there was no flare until the last second when an abrupt input was made once it became obvious that it should have been done earlier. Touchdown loading was over 3.5g.
Then they bounced and during the bounce, the F/O's beverage container fell on the floor. This would really not be the ideal time to pick it up but guess what?......the F/O, still flying the aircraft reached down to do exactly that. A subsequent touchdown was nosegear first.
While taxiing in, the captain mentioned that a there would have to be a tailstrike inspection and the F/O mentioned that to ATC. ATC didn't understand what was said and asked for clarification. The captain said to report severe turbulence. Therefore no runway inspection was made.
Actually, I did have a good hard landing by AC this past summer in an Embraer....nice weather too.
Eric Janson
pelmet wrote: Mon Jan 03, 2022 9:13 am The report is out.
The pictures on page 7 of the report are 'interesting' to say the least! :shock:
Surprised there wasn't an engine pod/flap strike (not sure what comes first on this aircraft).
