King Air at Gillam, MB
Re: King Air at Gillam, MB
The ad probably has to do more with the pay and morale, than the accident.
Bork Bork
I'm not saying that it is what happened but the routing it sounds like from the RCMP was YWG - YYQ. If this aircraft landed in YWG with YBR or YQK as an alternate thats about 30-45 ish mins of gas + 45 mins of reserve gas... about 1:30 will get you awfully close to Gillam if fuel was ordered in YWG but never arrived.
Does the route make any difference if you don't have enough fuel to finish the flight?
CGT is mothballed outside the shell hangar in YWG. Missing it’s engines, tail, etc.FICU wrote: ↑Thu Apr 25, 2019 7:59 pmThanks... I have a lot of time in CGT and ZPW from 15 years ago. Tough to see that happen to a company I spent over 6 years at.PostmasterGeneral wrote: ↑Thu Apr 25, 2019 6:22 pm By the above photo, high float landing gear, wing lockers, and 3-bladed props?
That’s gotta be FRMV...
ZPW is still flying as far as I know.
RIP CGT... it was a workhorse!PostmasterGeneral wrote: ↑Fri Apr 26, 2019 1:00 pm CGT is mothballed outside the shell hangar in YWG. Missing it’s engines, tail, etc.
- IMG_0089.JPG (462.83 KiB) Viewed 2310 times
- IMG_0069.JPG (474.58 KiB) Viewed 2310 times
One of the nicest flying straight -200’s I ever had the pleasure of driving. Serial number 003 was she?
Was at Wasaya before KAL got it. I really enjoyed the performance it had with the Raisebeck mod and 4 bladed props and no autopilot. A completely different animal to ZPW. Those photos were taken from ZPW on a return flight to Rankin from Churchill. John F. was flying CGT with Tanice and I had Tim P. with me taking the pics. We had some formation fun and great times when it was a Mom and Pop company!
A couple more for nostalgia...
- IMG_0091.JPG (472.67 KiB) Viewed 2057 times
- IMG_0093.JPG (482.04 KiB) Viewed 2057 times
The auxes are transferred directly to the nacelle tank via the jet pump and to the engine. A flapper valve keeps the main fuel from entering the nacelle tank until the auxes are empty and the nacelle level/pressure drops due to the jet pump stopping.goingnowherefast wrote: ↑Thu Apr 25, 2019 3:22 pm Except on a King Air, you transfer the aux fuel into the mains as there's room to accept it. By landing time, they'd long since have emptied the aux tanks and be running on the main tanks. Fuel would have been mixed long ago.
It will be interesting to see what the real investigators discover.
It is possible for main fuel to be contaminated and aux fuel to not be. Unlikely, but possible.
Its been a while since flying the KA200. The aux fuel, is it electrically pump or does it use the jet pumps from bypass fuel? I seem to recall that if there is no fuel in the mains, it wont transfer? Maybe an alternate theory was lineman filled wrong tank, and in hurry crew simply looked at total litres, but not enough fuel in the mains to siphon all from the aux's...... and tried to stretch it.
It uses a jet pump that takes fuel from the motive flow valve and the engine driven boost pump.
It’s nacelle fuel that you need. If you don’t have nacelle fuel, you’ve got more problems.
You’re not supposed to have empty mains and full auxes, and it’s not really possible to burn the mains and the nacelle dry first on both engines unless both motive flow valves are stuck closed and you’ve got both no fuel transfer lights on.
But yeah... I don’t know how you don’t grab enough gas either. Order the fuel, watch them fuel, get the fuel ticket and look at the amount, look at the gauges, read the checklist. Not one but two of you.
I believe they declared a fuel emergency shortly before actual event. Fuel gauges on this aircraft are not great and are MELable. Been there done that. If they were, there is no cockpit indication of fuel on board and first indication would be the fuel pressure light. For whatever reason they didn’t have the fuel they thought they had.
These aircraft are G1000 equipped. Provided you punch in the right fuel load on start up it will automatically calculate what you will have on descent and be reasonably accurate.
[/quote]
Since the mains are always filled first, and the aux are always burned first......possible, you say? When pigs fly.
They ran out of gas.....still nobody willing to stand on their hind legs and say it?
Illya
With a huge Mb medevac contract under decision you can bet EIC will be doing all they can to brush this under the rug as Keewatin was their best player to do bidding with. I’m actually surprised the LifeFlight/union folks and gov opposition aren’t using this as ammo against the privatization.Since the mains are always filled first, and the aux are always burned first......possible, you say? When pigs fly.
The auxes are transferred directly to the nacelle tank via the jet pump and to the engine. A flapper valve keeps the main fuel from entering the nacelle tank until the auxes are empty and the nacelle level/pressure drops due to the jet pump stopping.Illya Kuryakin wrote: ↑Sun Apr 28, 2019 11:01 am [quote=iflyforpie post_id=<a href="tel:1076459">1076459</a> time=<a href="tel:1556419860">1556419860</a> user_id=16238]
[/quote]
Illya
[/quote]
Stranger things have happened.
Sediment or water is going to be the first thing drawn out of a tank. First into the mains held back from the engine by the flapper valve, and will go to the lowest point on the nacelle tank as soon as auxes are dry.
I don’t really care if they ran out of gas or didn’t. They probably did. Why is that so important to you?
Doc just wants to blame people.
That being said, it does take some skill to either have a dual engine failure or run out of fuel in a twin turbine. I can think of a couple instances, but it's pretty rare. I'm willing to bet that the combined experience in the cockpit totals less than the average of our King Air F/Os.... pay peanuts....
I heard they are in the middle of pilot contract negots. Tough to negotiate with the boss if they did burn the tanks dry.....porcsord wrote: ↑Sun Apr 28, 2019 2:39 pm Doc just wants to blame people.
Since the mains are always filled first, and the aux are always burned first......possible, you say? When pigs fly.iflyforpie wrote: ↑Sun Apr 28, 2019 1:54 pmThe auxes are transferred directly to the nacelle tank via the jet pump and to the engine. A flapper valve keeps the main fuel from entering the nacelle tank until the auxes are empty and the nacelle level/pressure drops due to the jet pump stopping.Illya Kuryakin wrote: ↑Sun Apr 28, 2019 11:01 am [quote=iflyforpie post_id=<a href="tel:1076459">1076459</a> time=<a href="tel:1556419860">1556419860</a> user_id=16238]
Illya
[/quote]
[/quote]
Why is it important to me? Seriously? Doesn't bother you to have crews flying around running out of gas? Bothers me.
Illya
