I've seen pictures of the aircraft upside down on the strip, close to the south end. There is a fair bit of damage to the tail feathers, which would have whacked down hardest in the flip. Other than that, it looks like a noseover that you'd get with too much brakes. One prop blade is bent back, the other doesn't seem to have any damage. The prop shaft may be broken and the engine moved on the mounts. The windshield does not appear to be broken, there is a small crease in one side of the cowling but the occupant area shows no damage at all.AirFrame wrote: ↑Fri Jul 31, 2020 6:17 amThe aircraft was apparently not badly damaged (structurally) so I would tend to agree. But given the location there could be any number of things that the plane nosed over and came to rest on... Pointy rocks, stumps, etc. I've been told it was head trauma that caused the fatality.
Not clear whether it nosed over on takeoff or landing. As said above, it sure doesn't look like something that would cause serious injuries.
Any word on what the other woman's injuries were?
