Electrical Wiring Harness Installers - Contract - Toronto
Message
Author
portia
#1 Post by portia » Sat May 13, 2017 6:05 am
We are looking for at least 12 Electrical Assemblers for long term contracts in Toronto
Toronto:
Hourly Rate: Maximum $31.00/hour employee status (according to experience)
Hourly Rate: Maximum $40.00/hour Incorporated (according to experience)
Per Diem 100$ per day (they will have a 100$ Per Diem for the weekend if they work on the Friday and on the Monday) **THE PER DIEM IS NOT FOR RESIDENTS OF ONTARIO**
Role and responsibilities
• Performs electrical assembly operations; such as soldering, wiring, cutting, chassis marking, preparing terminations, harness or cable forming and lacing
• Performs all duties required to lay out, fabricate/modify and install electrical wiring and coaxial cable on aircraft
• Checks, tests and troubleshoots electrical systems for conformance to specifications and perform repairs, removal, and reinstallation of wiring as necessary
• Cut wire lo length, strip insulation from wire ends and insulates connections with plastic sleeves
• Working from various drawings and work order and respect the schedule requirements
• Properly use a wide range of hands tools and equipment such as: soldering irons, resistance soldering units, power drivers, pliers, wrenches, screw drivers, spray guns, crimp tools and etc
Your profile
• Two (2) years experience assembling mechanical and/or electrical systems
• Understanding the electrical principles
• Able to read drawings or blueprints required
• Good manual dexterity
• Good Analytical skills
• Ability to work under pressure and able to work in a constant evolving and changing environment
• Flexible work shift (day, evening, night, week-end)
• Bilingual
Education
You have professional degree in mechanical or electrical or structural assembly aircraft or equivalent
Please send a Word version of your CV to Karen Roe - karenr@tes.net
'97 Tercel
Re: Electrical Wiring Harness Installers - Contract - Toronto
#2 Post by '97 Tercel » Sat May 13, 2017 3:04 pm
That's nice.
chowda
#3 Post by chowda » Tue May 16, 2017 10:22 pm
Hey OP, have you not noticed that this isn't the "jobs" forum???
Im thinking you haven't as I don't see any of your several other posts in this section posted in the "jobs" forum.
Internet is pretty hard, huh?
Return to “Employment Forum”
