Air Bravo minimum first officer times?
Message
Author
#1 Post by 7507 » Thu Dec 28, 2017 12:13 pm
Anyone hired under 1000 hours?750?500?
Thanks in advance
dogfood
Re: Air Bravo minimum first officer times?
#2 Post by dogfood » Thu Dec 28, 2017 12:59 pm
I think all your need to work for them right now is a pulse lol
nightbird
#3 Post by nightbird » Thu Dec 28, 2017 2:42 pm
Not sure if they have other contracts now but it used to be minimum 500h to be able to do the Ornge flights and 1000h to fly Hydro contracts. Under 500 typically you would be dispatching and flying the odd charter that came in that didn't need the previous minimums so depending on how low time you are it could take a while.
Last thing I heard they were trying to set up some sort of cargo run out of Winnipeg? not sure...
#4 Post by 7507 » Fri Dec 29, 2017 4:43 am
What does a typical pilot schedule look like at Bravo, anyone from Bravo with a comment.
C-FDPB
#5 Post by C-FDPB » Fri Dec 29, 2017 7:54 am
Don't fly for bravo, but a good friend does and said it was 4 on 4 off. Just about all full duty days.
#6 Post by 7507 » Fri Dec 29, 2017 11:15 am
Is it true they won't hire you if you have a side part time job ?
garfield
#7 Post by garfield » Fri Dec 29, 2017 2:56 pm
I know 705 operators who hire 250 hours guys, I don't think you need more than 200 hours to fly a PC12 from the right seat...
nightbird
#8 Post by nightbird » Fri Dec 29, 2017 4:38 pm
It’s in the contract with the customer(Ornge and Hydro 1), even if they want to they can’t put anyone with less than the required minimum on those flights or they could loose the contract.
172_Captain
#9 Post by 172_Captain » Fri Dec 29, 2017 8:16 pm
Knowing what I know now, there’s no way in hell I’d do medevac in Northern Ontario in a single. On top of this, Bravo already has a reputation. Thunder, Wasaya, JV are all down the road with much better reputations and aircraft choice.
SuperchargedRS
#10 Post by SuperchargedRS » Sat Dec 30, 2017 8:26 am
Well seeing how it was built to be a single pilot ship, probably not lol
Knowing what I know now, there’s no way in hell I’d do medevac in Northern Ontario in a single...
Why?
Would you do it in a piston twin?
#11 Post by Cat Driver » Sat Dec 30, 2017 9:19 am
Well lets think about that for a moment.
We are a hundred miles from any airport at night and an engine quits.
Would I rather be flying a single engine turbine or a piston engine twin?
piperdriver
#12 Post by piperdriver » Sat Dec 30, 2017 9:33 am
Are you trolling? The single vs twin in remote northern ontario or manitoba etc. has been debated to great length on this forum before. The PC12 has in immaculate safety record in Ontario and I think that should speak for itself. By the way what company is jv?
dogfood
#13 Post by dogfood » Sat Dec 30, 2017 11:37 am
Would take a pc12 anywhere in Canada over a navajo and I've flown both
DrSpaceman
#14 Post by DrSpaceman » Sat Dec 30, 2017 1:10 pm
I've experienced a pt6 failure personally. Had I been in a pc12 I wouldn't be here today.
172_Captain
#15 Post by 172_Captain » Sat Dec 30, 2017 8:24 pm
Maybe immaculate but certainly not infallible. It’s a matter of personal opinion really. My opinion is when I’m departing YTL at night for example, I want more then one engine to rely on. While I haven’t suffered one personally, I’ve seen both PT6’s and Garretts fail, all made it back to base due to being multi engined. In fact, it was a close personal friend of mine who suffered an engine failure flying a single engine PT6 last year in the forces and had to eject. Lukily he had that option.
JV is Bearskin.
goingnowherefast
#16 Post by goingnowherefast » Sun Dec 31, 2017 10:53 am
There are PC12s that have had engine failures and glide to an uneventful landing. Then there are Navajos that have engine failures and can't maintain on the remaining engine. Don't go crying "overweight, yadda yadda". When it's +30*c outside and 100lbs under gross, your 1970s era PA-31-350 will be slowly descending while overheating the remaining engine. Cool day, light load, it will do 300'/min upwards, but how often does that happen? Also, that PT6 is a lot less likely to fail than one of two Lycomings.
Where would you rather be? At FL240 with no engine and 3 airports in gliding distance or at 3000' and slowly descending with one failed engine and nothing within the "drift down" range.
172_Captain
#17 Post by 172_Captain » Sun Dec 31, 2017 5:58 pm
Why are we discussing PC12 vs a Navajo? None of the companies I suggested the OP check out fly piston aircraft, and neither do I. It’s single turbine vs twin turbine. When I’m 150 miles away from the nearest airport in January I can tell you which aircraft I’d rather be in.
Return to “Employment Forum”
