DOH merge.
Re: DOH merge.
It's hard to foresee AC retraining most of the of Transat pilots to comply with the ACPA contract, that would cost millions. It's more likely that AC will sit down with ACPA and work out a deal to take advantage of 700 trained pilots and the lift they provided, at a lower cost than ACPA pilots would, ASAP.
I don't see the TS brand being erased that quickly, the brand and revenues it generates are linked to the airline. Tying the two revenue streams together and arranging the routes to maximise lift and revenues will be the game, not parking the planes to train around 1000 pilots (guessing 500 TS and 500 AC).
Re: DOH merge.
Good question. My wife is a stay at home parent so I am flexible.altiplano wrote: ↑Sun May 19, 2019 10:31 amIf your priority is time off at home, which infers you aren't working extra overtime days, how are you making more than a mainline pilot same type/status?126.75 wrote: ↑Sun May 19, 2019 10:22 am I am at Rouge and have been for about 4 years. I work less days per year than my ML counter parts and earn more money than them (compared with ML friends). I have the ability to get most days off that I want, and can "generally" choose the kind of flying I want.
I can do a fair bit of draft and drop situation. I will not work over 16 days. I am flexible and ask for less days of work and will do a few extra days, though I have not done any recently. 319 C. The 767 pay rates vs ML are really bad. 319vs 320 are pretty close especially considering many months its all day flying anyhow.
I am not one of the guys blowing their brains for an extra 150k a year or anything but when 10 hours of draft is worth >5k it adds up fast.
Re: DOH merge.
How is this difficult to understand?digits_ wrote: ↑Sun May 19, 2019 9:52 am
How? Why? Pay isn't going down. Just because someone else would, hypothetically, catch a break, doesn't mean you are losing money.
Air Transat consists -among other things- of planes and pilots. The pilots are merging into AC. The planes, you could have some arguments, but either way, whether it's keeping the original AT planes or the planes are going to be replaced, AC will be operating more planes after the merger than before the merger. Let's say, worst case scenario for AC pilots, that the AT pilots get the right to fly those spanking new airplanes. How will this negatively affect AC pilots? I truly don't see it. Those planes wouldn't be there if it wasn't because of the AT merger.
The money is in bigger airplanes. Someone who gets 500 people on top of him in the seniority list might never see WB captain spot due to the way demographics works against him. Or he will see it for fewer years.
Re: DOH merge.
The 500 pilots slotting ahead come with aircraft, the ratio stays the same for career progression. BTW, I'm pretty sure TS operates the aircraft with less crews per than AC, so it will create even more upgrades.Ki-ll wrote: ↑Sun May 19, 2019 11:03 amHow is this difficult to understand?digits_ wrote: ↑Sun May 19, 2019 9:52 am
Re: DOH merge.
You don’t know the fleet plan for the AT airplanes. AT has more junior pilot group as well. You have to look at a 30 year career progression, not next 5 years. AC 330 rates were less than 777 rates last time I checked.TFTMB heavy wrote: ↑Sun May 19, 2019 11:11 amThe 500 pilots slotting ahead come with aircraft, the ratio stays the same for career progression. BTW, I'm pretty sure TS operates the aircraft with less crews per than AC, so it will create even more upgrades.Ki-ll wrote: ↑Sun May 19, 2019 11:03 amHow is this difficult to understand?digits_ wrote: ↑Sun May 19, 2019 9:52 am
Re: DOH merge.
AT brings in wide body airplanes as well. A mix of senior and junior people. Senior people flying AT widebody will most likely be flying widebody after the merger, but they brought "their" own planes. So no AC pilot is negatively affected.
Junior people at AT will slide in on the junior spots at AC (assuming DOH). They might want to fly widebody, but the amount of widebody spots increased due to the merger. So on average that shouldn't change much.
The only problem you could have, in this scenario where some AC pilots could be negatively affected, is in the group of pilots at air transat flying a narrowbody, that have more seniority than the most senior narrow body AC pilot that want to fly a widebody. How big would that group be?
Big enough to screw everyone over and go for BOTL? I doubt it.
Re: DOH merge.
Without the fleet plan and seeing how exactly DOH would work it is all assumptions at this point.digits_ wrote: ↑Sun May 19, 2019 11:21 amAT brings in wide body airplanes as well. A mix of senior and junior people. Senior people flying AT widebody will most likely be flying widebody after the merger, but they brought "their" own planes. So no AC pilot is negatively affected.
You have to look at the effect 20-25 years down the road, together with immediate impact.
I don’t think it is all that rosy for AC pilots.
Re: DOH merge.
Well, there is also another group affected.digits_ wrote: ↑Sun May 19, 2019 11:21 amAT brings in wide body airplanes as well. A mix of senior and junior people. Senior people flying AT widebody will most likely be flying widebody after the merger, but they brought "their" own planes. So no AC pilot is negatively affected.
Those who decided to stick it out at an Express carrier because they were told that was the "way to AC," finally made it to mainline in the last year after AC decided hiring Westjet pilots instead for a whole summer two years ago was a better idea... Now they made their decision to stay loyal to the AC brand instead of going to AT like many colleagues did at the time and will have ALL 600 pilots slot in ahead of them.
Hi.
I am completely conflicted by this because I know DOH is the right thing to do but when you see it effecting you and your career progression so significantly especially AFTER staying loyal to the AC Express brand it feels a bit like betrayal. This will affect my lifestyle for how long I'll be stuck on reserve, ability to upgrade (which was a factor used to choose to accept this job) and long term pay.
That being said IF ACPA can open their eyes and start working for those of us at the bottom of the list and fix the horrendous reserve rules, get significant pay raises including the abolishment of flat pay and raises elsewhere to bring us closer to our US counter parts then I can see myself living with it.
If nothing on the pay and work rules changes and all that happens is a merger of the list I'm not going to be thrilled. Sure more widebody aircraft.... Yay. But I won't see those for years and now there's 600 future WB Captains ahead of me. All while I'm sitting on a shit reserve schedule and making $60,000 a year.
I'm still blown away I had to take a pay cut from Jazz to come here.
Re: DOH merge.
I feel for you Express guys and also all the Transat guys that have already switched to AC who effectively flushed their seniority down the toilet if DOH goes through.
Re: DOH merge.
Nice to know at least some people care.
I just hope those at the top who control where negotiations go don't forget about us....
Since my career progression will be stunted by this, I better hope to see some short term improvements that make he bullet easier to bite.
But I don't have high expectations.
Re: DOH merge.
Do you know the fleet plan? What are the stats on age in both groups? There's a lot we don't know but you seem to think AC pilots will get screwed? I highly doubt they will re-train TS pilots in the near future, the name of the game is profits, not pissing away 50 million dollars on training.Ki-ll wrote: ↑Sun May 19, 2019 11:20 amYou don’t know the fleet plan for the AT airplanes. AT has more junior pilot group as well. You have to look at a 30 year career progression, not next 5 years. AC 330 rates were less than 777 rates last time I checked.TFTMB heavy wrote: ↑Sun May 19, 2019 11:11 amThe 500 pilots slotting ahead come with aircraft, the ratio stays the same for career progression. BTW, I'm pretty sure TS operates the aircraft with less crews per than AC, so it will create even more upgrades.
Re: DOH merge.
If you're a new hire, there's a pretty good chance this would benefit you greatly, since Transat is hiring full GS's every month because of duty regs (100 additional pilots required) and by the time all this flushes out a year from now you'll get probably 100 guys instantly UNDER you.thesimplelife wrote: ↑Sun May 19, 2019 11:59 amWell, there is also another group affected.digits_ wrote: ↑Sun May 19, 2019 11:21 amAT brings in wide body airplanes as well. A mix of senior and junior people. Senior people flying AT widebody will most likely be flying widebody after the merger, but they brought "their" own planes. So no AC pilot is negatively affected.
Hi.
Re: DOH merge.
I hope so.DanWEC wrote: ↑Sun May 19, 2019 1:29 pmIf you're a new hire, there's a pretty good chance this would benefit you greatly, since Transat is hiring full GS's every month because of duty regs (100 additional pilots required) and by the time all this flushes out a year from now you'll get probably 100 guys instantly UNDER you.thesimplelife wrote: ↑Sun May 19, 2019 11:59 amWell, there is also another group affected.digits_ wrote: ↑Sun May 19, 2019 11:21 am
Hi.
I'm just really on edge because I don't like uncertainty.
Even if it ends up benefitting is greatly I hope the union is able to extract some leverage to try to improve some of the things I mentioned. Flat pay, overall pay, reserve rules and pension.
It's going to be an interesting time ahead for sure. And, I'm sure in the mean time AC will still continue to hire as they were planning too.
Re: DOH merge.
I know it's off topic but with that wording how do they get away with having jazz/sky regional/georgian operate since they're not AC pilots but do AC flying?Sharklasers wrote: ↑Thu May 16, 2019 11:32 amJean-Pierre wrote: ↑Thu May 16, 2019 11:20 am I think everyone is getting worked up over nothing. I don't think they will merge the company. At least not with Mainline. Maybe with Rouge but that was a risk they took when they left Mainline for Rouge so they can not cry foul too much about that.
They can't. Why do you people keep saying it?
http://negotech.labour.gc.ca/eng/agreem ... 23006a.pdf
1.02.1 All Pilot Positions and all flying performed by or on behalf of the Company or its Affiliates, including all flying utilizing the Company IATA designator code (AC or ACA) or future similar designator code will be occupied and performed by Air Canada Pilots exclusively in accordance with the terms and conditions of this agreement.
Such Company flying will include, without limitation, all revenue, non-revenue, scheduled, unscheduled, passenger, cargo, placement, ferry, charter, scheduled charter, sports charter, training, maintenance test flights and publicity flights
1.05.10 If Air Canada is involved in a merger or acquisition and the pilots of the merged or acquired carrier are consolidated with Air Canada’s Pilots, then any aircraft of the merged carrier that are added to the mainline fleet shall not count as Mainline Baseline WJA, Mainline Baseline NJA, Mainline Growth WJA, Mainline Growth NJA, or for the Growth Ratios as defined in L74.01
Simple put;
A.) For the Aircraft to go to Rouge the pilots would have to be merged.
B.) The merged Aircraft will not be able to be used against the rouge growth shrink ratio.
C.) the Rouge growth shrink ratio at this time does not allow for anymore widebody aircraft to be added
D.) The rouge growth shrink ratio as is stands today has room for approx 8 new fins to be added to rouge.
Re: DOH merge.
Scope and Capacity Purchase Agreements. The AC pilots gave it away for a few crumbs years ago.goleafsgo wrote: ↑Sun May 19, 2019 1:36 pmI know it's off topic but with that wording how do they get away with having jazz/sky regional/georgian operate since they're not AC pilots but do AC flying?Sharklasers wrote: ↑Thu May 16, 2019 11:32 amJean-Pierre wrote: ↑Thu May 16, 2019 11:20 am I think everyone is getting worked up over nothing. I don't think they will merge the company. At least not with Mainline. Maybe with Rouge but that was a risk they took when they left Mainline for Rouge so they can not cry foul too much about that.
Simple put;
Re: DOH merge.
Falls under CPA in 1.10.goleafsgo wrote: ↑Sun May 19, 2019 1:36 pmI know it's off topic but with that wording how do they get away with having jazz/sky regional/georgian operate since they're not AC pilots but do AC flying?Sharklasers wrote: ↑Thu May 16, 2019 11:32 amJean-Pierre wrote: ↑Thu May 16, 2019 11:20 am I think everyone is getting worked up over nothing. I don't think they will merge the company. At least not with Mainline. Maybe with Rouge but that was a risk they took when they left Mainline for Rouge so they can not cry foul too much about that.
Simple put;
Re: DOH merge.
Re: DOH merge.
Yeah, fair enough.TSAM wrote: ↑Sun May 19, 2019 1:52 pmTry going through 9/11, recessions and layoffs like many of us have. It's the nature of aviation unfortunately.thesimplelife wrote: ↑Sun May 19, 2019 1:32 pm
I hope so.
Re: DOH merge.
They might slide ahead of them, but they also bring planes. That's the big difference.thesimplelife wrote: ↑Sun May 19, 2019 11:59 am
If somehow, 600 AT pilots where hired and no planes were bought, or replaced or added, then yes, absolutely, I understand all points made here.
But there will be more planes. So it won't matter. More pilots, but more planes. Those pilots mentioned in your example could be jealous that other pilots are getting into AC "easier" if you wish, but it won't affect the junior AC pilot's careers. Trying to send them to BOTL because you are jealous or envious of others is a bad motivator.
