DHC-2 Weight & ,Balance
Help! Just in the process of purchasing a commercial beaver. We will use a see gee as our main w&b calculator.
Can anyone send me what they use for manual calculation.
Thanks in advance.
Thanks in advance.
Re: DHC-2 Weight & ,Balance
You are gonna need the W&B addendums from the specific Beaver to determine your starting index on the SeeGee. Or are you simply looking for a generic Aircraft Manual W&B section?
These planes have modified so much that the manual does not do much good, in most cases.
I have a C G calculator with numbers up to 5370. They are good for any Beaver if you want mine. I never use it now.
I also have the instructions on set up here too, I think. As far operations manual you can set it that you use the Cee Gee for all calculations, if you wish.
Bob Bates
Bob Bates
Thought it was just load up till the rear spreader bar is just under water; then put the heavy stuff up front!
if you run an IPAD and foreflight, they will add your w+b to it, with the plus being you can send to there server for savings(just need TC's sign off) have a GW/arm on your paperwork, and the rest saved for audit when in cell signal
also put in a stratus or the like, and have ads-b and an ahrs unit for about 700$
If you have a Google account, I can send you a W&B and flight planning file.
For a preview:
https://www.wildblueaviation.ca/weight-balance
The file at the bottom of the page. DM me, if you’re interested.
For a preview:
