In 2008 I completed basic land survival with the RCAF. The course was excellent and certainly made me much more confident that I could survive in the bush long enough to be rescued with very little equipment. The survival kits that you have with you are very small and compact as they fit in the pockets of your survival vest and if your flying a airplane with a rocket seat in the small pack attached to your harness.
I was thinking I may put together something similar for flying in the bush. One never knows when a simple three hour tour turns into a much longer stay. The goals of this kit are to include enough basic materials to make your stay in the bush as comfortable as possible while not taking up too much space and weight in the airplane.
The 1st item is a fishing vest, these are designed for people fishing in fast moving water. They have a manual life jacket inflation in case you end up in the water and lots of pockets for storing survival gear. The idea behind having a basic survival kit on you is sometimes you don't have the option of retrieving your kit from the back of the plane, with this vest it all comes with you. I found one that will likely do the job at cabelas http://www.cabelas.ca/index.cfm?pageID= ... 2&ID=26639 too bad they only come in olive drab...
In the pockets you will probably want to stuff the following:
Medicine (whatever you need for at least 72 hours--mark all drug containers with use, dosage and expiration date)
Compass (with instructions for proper use)
Paper and pencil (you can write down your compass bearings)
Map of the area
Lighter (Bic disposable or equivalent)
Waterproof matches
Magnusium stick (for starting fires)
Utility candle wrapped in aluminum foil
Utility knife (Leatherman, Swiss Army, etc.)
Canteen or water bottle that can hold about 750mls ( heavy duty freezer bags could work)
Water purification tablets
Rain poncho
Space blanket
25 feet of parachute cord
25 feet of snare wire
Small fishing kit
Snacks (some quick energy like jube jubes)
Signal mirror
Whistle
(Spot GPS??)
Many of these items are small and compact but will require some creative packing to fit in the vests of the jacket. I am going to be putting my kit together over the next couple of weeks so I plan to update this thead as things come together. My hope is that anyone who has a suggestion of comment will chime in.
C_172pilot
