Trans Air Twin Otter God's Lake Narrow's, MB
Mid April 1973. T.O is still in Midwest Airlines colors.
AP
AP
- IMG_8954.JPG (104.39 KiB) Viewed 2001 times
Re: Trans Air Twin Otter God's Lake Narrow's, MB
What a mess. Mud all over the place and up the fuselage. That refueling procedure might raise a few TC eyebrows if this was done by todays regulators.
The narrows still looks like a mess today
Lots of fuelling out of drums… dunno what the big deal is.
Re-fueling at Rankin Inlet January 1973. T.0. is CF-VTL
AP
AP
- IMG_8953.JPG (86.62 KiB) Viewed 1920 times
- GA MX Trainer Dude
The skinny line leading into the cockpit in the first picture is connected to the bleed air system and one engine is run to supply the air pressure through a regulator to pressurize the fuel drum. Pressure pushes fuel up the standpipe and through the no-go filter and into the aircraft tank. About 3 or so minutes to empty a drum this way.Lots of fuelling out of drums… dunno what the big deal is.
I don't remember ever wobble pumping any fuel into a twotter.
The big deal is that as far as I know the system was never "Approved" - but that didn't mean it didn't work well!!
I've been away from the aircraft for a lot of years - If someone actually has the approval for it let us know!!
Mx
You can train a monkey to ride a bicycle but you can't train it to fix it!!!
I've seen it done ferrying airplanes too
Sounds like a "city boy" comment. Look around, that's the bush circa 1970 or so in the early spring. Mud happens, but it will wash off.switchflicker wrote:What a mess. Mud all over the place and up the fuselage. That refueling procedure might raise a few TC eyebrows if this was done by todays regulators.
If you don't know,ASK!
Well I guess I'm a City Boy then. Of all the names people have called me, no one has ever noticed before! Life goes on.
Now hold my shovel while I clean this sh!t off my boots and get the loader.
Sw
Sw
