Monitoring your TATS for maintenance -dispatch
Message
Author
spinnindeep
#1 Post by spinnindeep » Fri Aug 14, 2015 1:06 pm
I am a dispatcher at my flight centre, and I was hoping to hear from some other dispatchers. How does you company monitors their TATS to determine how much time is left until next inspection?
we use myFBO software, but with it being tedious and having to find separate things in separate places, it gets kind of hard to keep some situational awareness sometimes. That being said, we use an excel spreadsheet to keep track of all of the planes, but they often get lost in translation with respect to the logbook/Software.
Out of curiosity, does anyone else use any system to make sure the info can be redundant, an accurate? trying to implement new ideas
helione
Re: Monitoring your TATS for maintenance -dispatch
#2 Post by helione » Fri Aug 28, 2015 6:46 pm
where I am we use AMT track tool for technical dispatch which is updated after the days flight(s) by a pilot, as well on the load sheets posted to our email address the dispatcher will indicate on the load sheet the times each aircraft was utilized and the time remaining till inspection.....so its a backup system to verify each other, it works okay
Return to “Maintenance”
