Elementary work??
Message
Author
cap41
Elementary work??
#1 Post by cap41 » Fri May 06, 2016 1:36 pm
On a cherokee 140. IS it considered elementary work to change the gas valves under each wing? The area were we test gas prior to each flight?
robertw
Re: Elementary work??
#2 Post by robertw » Fri May 06, 2016 1:50 pm
I'm assuming you mean the push type or twist type fuel drain valves. No this is not elementary work. See CAR 625 Appendix A.
cap41
#3 Post by cap41 » Sat May 07, 2016 5:22 am
That is correct screw type drain valve.
Greysierra
#4 Post by Greysierra » Wed May 11, 2016 9:30 am
Return to “Maintenance”
