Cessna push-pull master switch
Message
Author
tazin river
#1 Post by tazin river » Wed Sep 14, 2016 6:45 am
Hello folks
Would you know where I can order one of those push-pull master switch for a Cessna 180?
Could it be also replaced by a split switch which seems to be easier to find?
Re: Cessna push-pull master switch
#2 Post by PilotDAR » Sat Sep 17, 2016 4:47 am
Contact Mack at Skywagon City 705 484 5667, he probably has the switch available. It will be as removed condition though. I would be surprised to hear that Cessna, or anyone else stocked them as a new part.
Modifying to the split rocker switch would involve some work, and depending upon how the plane was configured, circuit changes. Do your homework before you undertake that. If your aircraft is generator equipped, the split switch might not be easily adaptable.
Return to “Maintenance”
