First inspection date for a new ELT
Post by photofly » Wed Mar 27, 2019 4:02 am
CAR 625 Appendix C specifies 12 month intervals for an ELT inspection.
When is the first inspection due for a new ELT - is it 12 months after manufacture, or 12 months after install?
For propellers, 625/G says explicitly, but it doesn’t say either way for ELTs.
Kirk: This is a dangerous mission. Likely, one of us will die. The landing party will be me, Spock, McCoy, and Ensign Ricky.
Ensign Ricky: Aw, crap.
Heliian
Re: First inspection date for a new ELT
Post by Heliian » Wed Mar 27, 2019 5:16 am
ELT requires inspections at manufacturers intervals, say a 30 day test, that would be at initial install and then every 30 days.
ELT recertifications and battery replacements are carried out from the last recert or replacement.
To keep you flying while the elt is out for recert, you're allowed to have it out for 30 days.
Post by photofly » Wed Mar 27, 2019 5:30 am
Right... but when does the 12 month clock for the out-of-phase inspection required by CAR625 Appendix C begin?
Date of install, or date of manufacture?
AirFrame
Post by AirFrame » Wed Mar 27, 2019 6:27 am
Date of last certification. If there isn't a sticker on the ELT that says when it was last certified, it's not, and it needs to be done.
Post by photofly » Wed Mar 27, 2019 7:57 am
It was last certified as new per the date on the Authorized Release Certificate provided by the manufacturer. That's all you need to install it. Question is, when is the first performance test IAW 571 Appendix G due?
Heliian
Post by Heliian » Wed Mar 27, 2019 10:25 am
c/o at the annual re-cert, as per my ARTEX literature.
corethatthermal
Post by corethatthermal » Wed Mar 27, 2019 10:47 am
Trudeau type answers on avcanada ! I can give another trudeau type answer!
Batteries are life limited, so if the ELT had been sitting 5 years on the shelf, it would at least be due for batteries AND a test after batteries are installed! There you go, I didn't answer the question either !
Heliian
Post by Heliian » Wed Mar 27, 2019 11:25 am
I think it's pretty clear, your mind is clouded.
Post by photofly » Wed Mar 27, 2019 3:53 pm
Well I think that's clear now. Thanks everyone :-)
corethatthermal
Post by corethatthermal » Thu Mar 28, 2019 8:10 am
A NEW ELT does not have a recert or replacement history because it has never been re-cert or anything re-placed !
Heliian
Post by Heliian » Fri Mar 29, 2019 5:06 am
As said above by another poster, your "NEW" ELT will come with some form of certification. It's that Certificate that you will start by. So yes, if your ELT has sat on a shelf for years you need to send it out.
corethatthermal
Post by corethatthermal » Fri Mar 29, 2019 7:56 am
Still doesn't answer the question, If your ELT has been on the shelf for 366 days, will it need the annual test if not ever installed and the battery is not due ?
( My opinion is Yes, it will need a test before installation and flight )
Heliian
Post by Heliian » Fri Mar 29, 2019 8:27 am
Yes, the parts tag will tell you when it was certified new, it is one year from that date.
Return to “Maintenance”
