To anti-seize or not?
ruddersup?
Post by ruddersup? »
Should you use anti-seize compound or not on spark plugs.
Different opinions here I'm sure, and I'm not a user. Wire wheel plug and thread chaser if need be.
What about changing spark plug washer? Necessary or not?
Your thoughts?
Heliian
Re: To anti-seize or not?
Post by Heliian »
Yes, but use the correct antiseize and clean off the old stuff really well.
As far as the gasket, you can reuse them if they're in good condition. We used to anneal them for reuse. They are a crush gasket so they only have a limited number of uses.
J31
Post by J31 »
Post by ahramin »
Yep, just follow the instructions. The gaskets are about 25c each when you buy them in bags of 100. That's 0.08% of my annual operating cost. Not worth thinking about.
ruddersup?
I've operated 5 Navajo's and we never used anti-seize compound. Wire wheel the plug and thread chaser if needed.
Never had a seized plug this way. We found, eventually, residue buildup with anti-seize so why use it if there is a possibility it could short the plug. New apprentice could create a headache. If there is a possibility it can go wrong sooner or later it will.
I'm still using the KISS method, and just passing on what I've learned.
Post by ahramin »
I suppose one thing to consider is how often the plugs are coming out. A machine flying 300 hours a year is different from one that only has the plugs out during yhe annual inspection.
What would be the downside?
Jungle Jim
Post by Jungle Jim »
I used the Champion 2612 spark plug lube. It is a water/graphite mixture. It is quite thin so a bottle will last a lifetime.
Jim
BMLtech
Post by BMLtech »
I asked a spark plug company rep about this at a trade show once and he said the downside is that anti seize can have unpredictable effects on the heat transfer from the spark plug into the head.In the automotive sector, seizing issues are much more prevalent now due to spark plug replacement intervals of 120000km or more.
fish4life
Post by fish4life »
I just did my car plugs at 140k like it recommended and they were no problem, I was actually surprised how easy it was.
Heliian
Post by Heliian »
Follow manufacturers instructions.
Lubrication or lack thereof is important in the application of proper torque for the plugs.
Return to “Maintenance”
