Absolutely, however not all private owners choose to get their maintenance done at an AMO because of...you guessed it, the extra rate per hour that is charged. And the extra rate that is charged is usually needed to cover things that are required because of regulation.But if the work is done at an AMO they are required to update the W&B if the airplane is commercial or private.
And again, I understand that not all owners fit in that category, I've just seen enough to get the broad strokes. The ones that do get their maintenance done at a good AMO will understand.
