Marvel Schebler MA-3SPA CARB PROBLEMS
Recently the carb on my Citabria with an O-200A had a fuel leak. I sent the carb to a shop and had it repaired. While at the shop a one piece venturi and an atomizer style fuel nozzle were installed. Now my engine is not making full power and runs very rich. On a ground run, if I go full throttle the engine runs very rough and emits black smoke, if I throttle back to 3/4 throttle the RPM goes up and it runs smoother. I have sent the carb back to the shop and they even ran it on a test cell engine and can find no fault. Has anyone here had this problem? If so what was the cure?
FLYING FOR FUN
My Precision carb does exactly as you describe! It's been tested to hell and back a few times as well as the engine. Still to this day no satisfactory answers, even talked to a factory rep at Oshkosh about it and he suggested I send them the carb as he said they are the only ones who can properly flow test the unit.
Putting money into aviation is like wiping before you poop....it just don't make sense!
Yes, I know about the AD but the two piece venturi works. Also the owner is the one responsible for maintenance these days. I'd rather fly a plane that performs as designed as opposed to a poor running one with a legal piece of paper on the book.
He should be able to state the situation in the log books and defer complying with the AD. ( quite a few champs are flying that have defered the spar inspection holes this way) I had a similar situation with the weight and balance when I bought my Stinson. The calculations done repeatedly over the years by qualified AME's were wrong. I revised them myself, sent the documents to TC and was told that the wrong calculations had to be the ones used because the AME's were deemed qualified persons. I challenged them on this and they did back down and accepted my calculations with my P.Eng. stamp in the end.
Jim
Jim
This is a very common problem with the SP3A, Keep sending it back until you are satisfied with it. I struggled with your situation several times in the past.
Also good job challenging TC with your stamp!! Ive done the same on several occasions, with mixed response from TC.
Perhaps ask for the "Engineer" that is fixing your carb, to adjust the float level down a bit.
Carb trouble
I can't beleive a transport inspector accepting an idiot with a pinky ring having any say in an aircraft issue. The ring is there to remind you dumb f@%ks that you screwed up.
Give me a break. Go build a bridge.
Re: Carb trouble
My friend, it is people such as you, that keep this industry in the toilet.Bulawrench wrote:I can't beleive a transport inspector accepting an idiot with a pinky ring having any say in an aircraft issue. The ring is there to remind you dumb f@%ks that you screwed up.
Go and get an education.
This is not directed at anyone here but since we are on the topic.
Do not confuse an education for intelligence as they are not interchangeable.
By the way since the owner is responsible for maintenance did he submit an SDR to Transport regarding the carb problem?
People should not have to fear both the government and the criminal. It should be that the criminal fears both the people and the government.
I personally would send the carb back and say nice try, but this time do it right. I just had a carb on our 172 that is for employee use back to the shop 3 times before it worked right.
And bula, buddy, lighten up a bit.. Maybe I should bring you some medicine... OK.. We'll just go to the Beav and I'll let you buy!!
you are correct, intelligent people pursue higher education.
hoptwoit wrote:This is not directed at anyone here but since we are on the topic.
Strega wrote:
(Strega's comment + attitude) / Higher education = Arrogance
You're comment smacks of it.
There are many intelligent people that have not sought higher education.
Perhaps a more appropriate statement would be. Intelligent people seek knowledge.
Please don't seek to elevate yourself by putting other people down. It's not becoming of the "Higher educated"
Kinda thought this might happen so in you're case we may have to apply the universal language of math. Let's see how could we write this formula?you are correct, intelligent people pursue higher education.
Carb trouble
Yeh, i guess i need to lighten up twotter . I think something struck a chord. My brotther has a pinky ring and as far as i remember his sh@t did stink when i was a kid. After all this is only for fun. Thanks Twotter.What day is cheep beer night anyway?
