Personal requirements for an AMO
Message
Author
CF-RYE
#1 Post by CF-RYE » Tue Mar 02, 2004 1:14 pm
Wondering what the personal experience requirements are for an AME to start an AMO? Any info, comments or opinions on this subject are appreciated.
Guest
#2 Post by Guest » Tue Mar 02, 2004 2:04 pm
Found this info. Sounds not too bad.
(1) Subject to (3), persons appointed pursuant to section 573.03 of the CARs shall meet the following standards of competence:
(a) except as provided in (2), they shall have acquired a minimum of six years experience in the performance or direct supervision of maintenance activities of the type undertaken by the organization, at least six months of which shall have been obtained within the preceding two years;
(b) they shall have achieved a grade of not less than 70% in a Transport Canada multiple choice examination on the Canadian Aviation Regulations applicable to a Maintenance Manager;
(c) their personal record in relation to aviation shall not include;
(i) any conviction under Section 7.3 of the Aeronautics Act; or
(ii) any combination of two or more convictions on separate occasions, under sections 571.10 or 571.11 of the Canadian Aviation Regulations.
Guest
#3 Post by Guest » Tue Mar 02, 2004 2:06 pm
(2) In the case of an AMO not holding an aircraft, avionics, engine, or propeller rating, the person appointed may have less experience than required by (1)(a) provided the certificate holder can demonstrate to Transport Canada that the lesser experience is appropriate to the scope of work undertaken by the AMO. The amount of experience required will be determined by the complexity of the work undertaken by the organization, but in no case shall be less than one year. The following guidelines may be applied in determining the required amount of experience:
phillyfan
#4 Post by phillyfan » Tue Mar 02, 2004 2:11 pm
That info was from me. It goes on and on after that, but it sounds like it can be done with as little as 1 year.
CF-RYE
#5 Post by CF-RYE » Tue Mar 02, 2004 4:13 pm
Thanx for the info fellas
#6 Post by ahramin » Wed Mar 03, 2004 3:20 am
Fellas? What? How many are there? Have you got a mouse in your pocket philly?
CF-RYE
#7 Post by CF-RYE » Wed Mar 03, 2004 9:06 am
I guess you don't know philly :D
Return to “Maintenance”
