AME tech exams
Re: AME tech exams
They are multiple choice questions with the usual 4 options, the question are on an archaic computer system, you'll need to bring a calculator, they'll provide scrap paper and a reference sheet of all approved aviation acronyms so don't waste your memory on those…
Here's some questions I can remember from the exams, they should give you an idea of the kind of questions you could see,
Standard Practices:
Number of faces in an isometric drawing?
Title block location in engineering drawings?
Sharpest bend permitted in aluminium sheet?
Bearing that can take radial loads?
Tool to find center of a shaft?
Bend radius allowance is what % of original diameter?
Which flared fitting can be identified by a shoulder between thread and flare cone?
Shear strength of a 2017T3 ‘crack free’ rivet?
Instrument air identification marking?
The diagram that demonstrates principal of operation is a what?
Aluminum forming without annealing should be done immediately after what? Ageing - heating - quenching - anodising.
NDT with least surface prep?
Acceptable time slot to test ELT’s?
Volume of a cylinder?
1 microvolt =?
Pascals, daltons, and Boyles laws?
Understand Ohm’s law and power (watts) and their calculation.
Electrolyte in a NI-Cad?
AC power in a capacitive circuit, current or voltage, leads or lags by how much?
Working voltage of a capacitor in an AC circuit should be how many time (or not) the actual voltage?
Terminal lug of a 20 gauge wire is what colour?
9 in binary?
A metals ability to be deformed is called what?
Monel consists of what % of nickel and alloys?
Hydraulic identification label?
Flash point is what?
AN bolt with 2 dashes?
Jo-bolt is what kind of fastener?
How many threads should be showing on a turn barrel?
A Skydrol hose can be identified by what?
Airframe:
Air flowing in thin sheets over a wing with no disturbance between layers is?
As airflow moves to trailing ege, boundary layer becomes?
Form drag can be classified as?
Chord=100” fwd CP is located what % from leading edge?
Aspect ratio 144sg.ft, span 24’, width?
A winglet does what?
Type of load when FWD press on elevator causing centrifugal force in opposite is??
Wing loading formula?
A difference in wash-in/out between wings is used to compensate for?
In differentially rigged ailerons which (up or down) moves more?
Doped patch repairs may be used on fabric covered surfaces if it doesn't exceed what size?
What would you clean bead seats with?
Compensating valve on a master cylinder does what?
Oleo initial shock is absorbed by?
Sluggish, jerky brakes on a multi-disc brake could be caused by?
2 major shimmy damper components?
Micron filters filter to what micron?
Type of pump used for high press (hyd)?
In a hydraulic system the relief valve with highest press setting is?
Manual control, cabin press to 3500’ at 8000’ climbs 500’ cabin alt now?
AC gens charge batteries through?
Static test leak down rate (ft/min)?
Fully integrated auto pilot controls around how many axis?
2 functions that can be selected to control alt?
A helicopter in forward flight changes course by?
Coriolis effect is associated with?
Helicopter artificial feel comes from?
Conical bearing are capable of what types of loads?
Moveable h/stab on a helicopter do what?
Vibration type associated with an out of track condition?
Constant amplitude vibration despite RPM change is associated with?
Tail rotor could fail to compensate if?
How would a tail rotor be dynamically balanced?
Powerplant:
3 primary factors affecting gas turbine thermal efficiency?
Highest press area in a turbine engine?
% energy absorbed by fan on a turbojet/fan?
Ball bearings on a shaft absorb what loads?
variable inlet guide vanes are actuated by?
Increase oil temp with no power change indicates what on a jet?
Oil in a turbine picks up most heat where?
Oil temp reg on a dry sump is located between which components?
Erratic oil press indication could be?
Starting sequence (turbine)?
Inflight flameouts are usually caused by what?
When does the starter disengage?
Turbine ignition systems are rated in?
Tacho-gen consists of?
Electronic tq ind. system includes cockpit indicator and?
4 lobe cam ring on 9 cylinder radial will rotate at?
What measures temp increase compared to a reference?
Oil in had lifter comes from where?
Compensator cam in radial mags operate at?
Cowl flap on ground should be in what position?
What component is distinctive of high tension mags?
How is an exhaust cabin heater inspected?
A radial with #1 at TDC #3 holds no press on compression tester, indiction of?
Excessive blow by on new rings is probable what?
Least likely to occur in direct fuel injection?
0.003 oversize stud prefix P003, colour of stud?
Front cone of prop consists of?
Standard Practices:
1 microvolt =?
9 in binary?
Airframe:
Powerplant:
Re: AME tech exams
Thanks for the info,
Wow you have a great memory btw , definitely a big help.I just received my Jeppeson airframe, general and powerplant plant test guides and study guide and was wondering if i need the jeppesen texts and ASA texts to go along with them.
thanks appame
thanks appame
Re: AME tech exams
These are really good as well. Downloadable PDF and free on the FAA website. Looking at the Technician books.
https://www.faa.gov/regulations_policie ... /aircraft/
Re: AME tech exams
I have just accomplished my ICS course through my company and I'm looking into writing my technical exams in the coming months. I know a lot of people comment on using the JEPPESEN A&P test/STUDY guide or the ASA study guide. My question is is there a difference between the two sets of information? I don't want to waste money on the sets of books if one is useless writing the AME Technical Exams.
Re: AME tech exams
Did u ever end up writing your tech exams and how did u make it. Was the jeppesen study guide and asa study guide helpful? ThanksDsut93 wrote: ↑Wed Aug 29, 2018 9:59 am I have just accomplished my ICS course through my company and I'm looking into writing my technical exams in the coming months. I know a lot of people comment on using the JEPPESEN A&P test/STUDY guide or the ASA study guide. My question is is there a difference between the two sets of information? I don't want to waste money on the sets of books if one is useless writing the AME Technical Exams.
Re: AME tech exams
Hey guys.
I’m really struggling trying to study for standard practice and Structures test. I’ve been out of school for a while now and I’m trying to do the TC exams. I’d really appreciate the help with some info on both exams, trying to get the “S” license.
Re: AME tech exams
Just did my standard pratice last week and airframe today for the M exam i can tell you that my exam questions almost matched 100% with what APPAME posted.
Mbg as for the S license exam i talked with the S guys at work and he said the standard pratice was simliar to the M license, but that a lot of Airframe questions were from AC 43.13
Re: AME tech exams
Dinny wrote: ↑Fri Mar 15, 2019 5:48 pm Just did my standard pratice last week and airframe today for the M exam i can tell you that my exam questions almost matched 100% with what APPAME posted.
What's appame?
Re: AME tech exams
Someone with the name Appame posted the questions he remembered from the exams above, I was mentioning him because it matched the questions I recieved during my exams.Notben wrote: ↑Wed May 22, 2019 6:15 amDinny wrote: ↑Fri Mar 15, 2019 5:48 pm Just did my standard pratice last week and airframe today for the M exam i can tell you that my exam questions almost matched 100% with what APPAME posted.
What's appame?
Re: AME tech exams
Which book should I use for AME-M exam? (including Standard Practice)
Which book should I use for CARs?
Re: AME tech exams
Edited
Re: AME tech exams
Hello All,
I am an AME with over 20 yrs experience outside Canada, looking to sit for the technical exams for the M2 license. However, due to my training school going through a few "restructuring" in the past 30 years, they are unable to find the curriculum which states the exact amount of hours and the subject breakdown for the curriculum.
My question is, if I do the ICS Aircraft Mechanic online course successfully, will I be able to sit for the M2 theory exams without any problems?
Many thanks,
Many thanks,
Re: AME tech exams
Hello All,
I am an AME with over 25 yrs experience outside canada, looking to sit for the technical exams for the M2 license. However, due to my training school going through a few "restructuring" in the past 30 years, they are unable to find the curriculum which states the exact amount of hours and the subject breakdown for the curriculum.
Many thanks,
Many thanks,
Re: AME tech exams
For the M exams, I used handed down notes from people who had done the exams with the jeppesen study test prep book.
On its own, the jeppesen book isn't enough for the canadian exams.
Send me your e-mail in a PM and i'll send you the study notes I used
CARS is super easy, going through the study guide CARS for AME is all you need to pass.
Re: AME tech exams
With the ICS diploma you will be able to sit the M exams, that's the path I took to get my M2.dakardakarAME wrote: ↑Mon Jun 17, 2019 8:28 am Hello All,
Many thanks,
Re: AME tech exams
Edited
Re: AME tech exams
hi mbg how are you doing so far on your tech exams ,have you taken the Structures test already if yes can you give some hi light on the coverage of the exams thank you. Choy
Re: AME tech exams
Hello guys,
Is there anybody who can suggest me books for sitting in TRANSPORT CANADA 'E' rating exam please or test guides? Would appreciate any feedback. thanks.
Re: AME tech exams
Hey there I have just been approved for my M2 exams is it possible for you to send me that notes you got
alanvanniekerk@yahoo.com
I'll really appreciate your help!
Re: AME tech exams
Please can you send me information to henrytaiye@yahoo.com. Very much appreciated
