AVCANADA
It is currently Tue Sep 27, 2016 6:47 am
Post new topic  Reply to topic  [ 15 posts ]
Author Message
 Post subject: Tap test hammer
PostPosted: Wed Mar 16, 2011 10:20 am
Offline
Does anyone know where to find a composite tap hammer? We've got some heavy inspections coming up and I tend to spend my loonies as fast as I get them.
http://www.heatcon.com/wind-energy/tool ... tap-hammer
I asked for a quote from this place about a month ago, and they ignored me.
I also checked Mac, Snap-On, Brown, USATCO, and MATCO. No luck.
Top
 Post subject: Re: Tap test hammer
PostPosted: Wed Mar 16, 2011 11:05 am
Offline
I know where you can get one for a nickel... :wink:
_________________
Top
PostPosted: Wed Mar 16, 2011 11:28 am
Offline
One manufacturer of helicopters suggests using an 8mm diameter steel rod 10cm long for tap testing composite blades. If you are going to be tapping that much that you need a hammer, have fun, after 2 hrs, all you hear is tap, tap, tap, tap......
Top
PostPosted: Wed Mar 16, 2011 3:31 pm
Offline
A representative of a certain helicopter manufacturer handed out lots of composite tap tool rods to our crews at one time.
Take a steel rod 1/4 diameter, about 2 inches long, round off the ends on a lathe. That's all it is.
Or take a small brass drift from Snap-On and use the rounded end.
I use both methods.
Top
PostPosted: Thu Mar 17, 2011 6:07 am
Offline
Just weld a steel ball on a stel rod,works well lasts a long time :)
Top
PostPosted: Wed Mar 23, 2011 11:03 am
Offline
Why would you want to tap test a hammer? :)
_________________
Top
PostPosted: Wed Mar 23, 2011 11:51 am
Offline
More importantly, when did they start being called hammers?
This is aviation. Tapometers people, tapometers...
_________________
Top
PostPosted: Wed Mar 23, 2011 10:00 pm
Offline
http://www.urbandictionary.com/define.p ... =tapometer
Nope - looking for a hammer
Top
PostPosted: Thu Mar 24, 2011 6:32 am
Offline
For christ's sakes, if you want to be called an engineer start sounding like one! It doesn't measure tapo's! It smashes stuff!
It is a solid state force transfer through leverage application device.
_________________
Top
PostPosted: Thu Aug 11, 2011 6:27 am
Offline
the tap hammer is a really small piece of alum, turned to a Boeing drawing,I have made about 500 of these things for the inspectors in my shop over the years.it's not meant for "smashing" things. lol
Top
PostPosted: Sat Jan 19, 2013 7:33 am
Offline
Do you have the drawing you built from that you could share with the rest of us? :)
Perhaps a wee scan?
Top
PostPosted: Sat Jan 19, 2013 12:37 pm
Offline
Hey - Plane Jane hammers are so last century :shock:
http://hotbonders.wichitechindustries.com/Asset/Electronic_Tap_Hammer_for_Composite_Damage_Assessment.pdf
http://www.google.com/patents/US6748791?printsec=drawing#v=onepage&q&f=false - Us Patent
You need one of these to be up to date!! LOL
Source to buy;
http://hotbonders.wichitechindustries.com/item/non-destructive-testing-device-tap-hammer-/rd-electronic-digital-tap-hammer/f4tap002?&forward=1
Most often there is a drawing of the tap test method and equipment in the manufacturers manual - try Standard Practices section.
I have had very good results with the big ball bearing welded to a 1/4 inch rod (6.35mm for you metric gearheads) - have also used big washers with the edges filed round - just make 100% sure that you do not damage the surface with whatever tool you are using. Don't forget to calibrate your ear - I find it interesting that many don't actually know what a defect sounds like. :prayer:
If I can find a drawing I will try and post it.
EDIT: - Link to Tap Test Hammer Drawing http://1pointperspecti.ucoz.com/load
This drawing is from MIL HandBook - 337 Section 10.
Hope that helps for a generic hammer - your aircraft manufacturer might have a different one that they want you to use.
Mutatis mutandis - (A caution to a reader when using one example to illustrate a related but slightly different situation. The caution is that the reader must adapt the example to change what is needed for it to apply to the new situation.)
Regards
Mx
Top
PostPosted: Sun Jan 20, 2013 5:35 pm
Offline
:lol: and dont forget to get the certificate saying its calibrated to a national standard :prayer: :lol:
Top
PostPosted: Fri Jan 09, 2015 8:34 am
Offline
For those that have the ability and resources to produce a manual tap hammer, please let me know if you would want to make a couple for me with a price included? Or if there is a manufacturer website that is valid where I could go and buy one. The Yard store and Brown aviation tools do not carry these. Thank you very much and please no weird remarks.
Top
PostPosted: Sat Jan 24, 2015 12:19 pm
Offline
try this one
File comment: try this one
Top
Who is online
Users browsing this forum: No registered users and 19 guests
Search for:
Jump to:
avcanada@gmail.com
AvCanada Topsites List
