AVCANADA
* AvCanada's Home Page * Topsites *Weather * Media Kit
It is currently Fri May 06, 2016 9:53 am
Post new topic Reply to topic  [ 15 posts ]
Author Message
 Post subject: Stall warning horn
PostPosted: Sat Apr 10, 2004 10:24 am
Offline
Hey all. Having trouble picturing how a stall horn actually works on a simple trainer ie. C150/172. What causes the horn to sound?
Is there a difference for something more complex, maybe a navajo?
Top
 Profile
 Post subject:
PostPosted: Sat Apr 10, 2004 12:01 pm
Offline
Wish i could draw pictures on this thing.
Normally the opening in the leading edge where the stall warning horn is is outside the low pressure area created on top of the wing. But when you get close to the stalling AOA, the low pressure area has now expanded to the point that the opening now has a suction on it from the low pressure. The horn is just a reed that vibrates when you suck on it.
On larger aircraft like a ho or king air there is a vane and electrical switch which work on the same principle. In normal flight the vane is pushed down but at high angles of attack the vane is pushed up. The switch activates a speaker in the cockpit. Due to one of my takeoffs last month i can attest that the one on my king air works. :oops:
When you get to jets and transport category size aircraft the stall warning is done by a computer.
Top
 Profile
 Post subject:
PostPosted: Sat Apr 10, 2004 12:15 pm
Offline
:shock:
Top
 Profile
 Post subject:
PostPosted: Sat Apr 10, 2004 6:04 pm
Offline
TOO LOW, GEAR
TOO LOW, GEAR
TOO LOW, FLAPS
TOO LOW, FLAPS
GLIDESLOPE
GLIDESLOPE
I'm getting kind of tired of that. And why is it a male voice? The US Air Force did a study and found that fighter pilots responded better to a female voice. So why didn't the rest follow suit?
Top
 Profile
 Post subject:
PostPosted: Sat Apr 10, 2004 6:15 pm
Offline
Hey Abramin :
I had a few girl friends that vibrated when I su.....no forget it, that is not aeronautical.
Cat
_________________
Top
 Profile
 Post subject:
PostPosted: Sat Apr 10, 2004 10:01 pm
Offline
The stall warning device in a Cessna 152 / 172 is actually mounted in the wing root just beside the cabin vent on the pilot side. The opening in the wing leading edge is connected by a tube to the device, which is a small metal reed similar to what you might find in a New Years Eve noise maker (but much more expensive).
As the angle of attack of the wing increases air begins to flow over the opening causing a low pressure area in the opening. This draws air over the reed causing it to vibrate. If you look close at the opening inside the cabin you may notice that it is a small megaphone to amplify the sound.
The air movement is similar to blowing across the top of a pop bottle, where the noise results from air passing in and out of the bottle.
_________________
Pilots get higher, SCUBA Divers do it deeper!
Top
 Profile
 Post subject:
PostPosted: Sun Apr 11, 2004 10:36 am
Offline
To get even more techy, when the AOA of the wing increases, the stagnation point moves closer to the underside of the wing. When it reaches a pre-determined point (stall warning indicator position) the dynamic pressure of the air now forces the metal tab up to complete the electric circuit, thus the stall horn. That's the basic concept. Also the lack of pressure above the tab, as stated above, also contributes to the movement of the tab.
Top
 Profile
 Post subject:
PostPosted: Sun Apr 11, 2004 10:48 am
Offline
I guess that would depend on whether you had an electric stall warning device or the kind usually found on the C152?C172"s most comonly used for flight training. I've never seen the electric device on a C152 or C172, but then I've never seen Nicole Kidman naked in my room either.
It could happen! :shock:
_________________
Top
 Profile
 Post subject:
PostPosted: Sun Apr 11, 2004 1:32 pm
Offline
Ah..yes yes. :oops:
Time takes it's toll on the memory and I'm trying to think back to the good ol'172 days.
Ah yes, now I remember the training, listen for a faint horn sound amongst the noise ;) but mainly watch for the onset of the buffet for a solid indicator.
Thx for the heads up OW.
Top
 Profile
 Post subject:
PostPosted: Sun Apr 11, 2004 1:33 pm
Offline
OW, the reason we are talking about electric stall warning devices is because he asked
Not because we think they are on Cessna 150s and 172s. :)
Top
 Profile
 Post subject:
PostPosted: Sun Apr 11, 2004 2:55 pm
Offline
The stall warning devices on an airplane all depend on the stall characteristics of the airplane they are installed on. Real simple airplanes like a Cub did not have any because of very benign stall characteristics. The little hole in the wing and reed in a 172 is there so no electricity is required, Again simplicity. Most airplanes that have gentle stall characteristics have a simple vane on the wing. Same idea. The Navajo and Kingair have a vane on the wing but they also have very benign stall characteristics. In the King Air 350, when it stalls, just go to max power with the power levers and it will fly right out just on brute power alone. 2200 horsepower helps a lot. Eventually you get into airplanes like a Metro which can get downright ugly in a stall and the manufacurer has a choice, design bad stall characteristics out or prevent them from stalling. Most manufactures will design a system that prevents the airplane from stalling, usually with a stick shaker, an electric motor that spins an out of balance weight attached to the column, and a stick pusher, a device that will physically push the control column forward with up to 60 lbs force. In the Metro they prevent it from stalling with a stick pusher. There is an angle of attack vane, either on a post on the right wing or on the nose, that senses angle of attack and also compares stall angle with different flap settings and as the airplane slows down, we get an aural warning and if that is ignored, the stick pusher will push the control column forward. This system has to be tested daily and if it fails, it is a no-go item. There are emegency procedures if it quits in flight. In the Gulfstream G1. there is a stick shaker that vibrates the control pole approaching the stalll. In a Lear 25, there is both a stick shaker and if that is ignored, a stick pusher will push the control column forward. And if you get going too fast, a stick puller will pull the control column rearward to prevent overspeed. The DC 10 has a stall avoidance system for each wing. Sometimes these systems can get quite complicated. What ahramin was shouting about with the TOO LOW FLAPS etc is the ground proximity warning system in larger airplanes. A completely different system with a different set of protocols. Works off the radar altimeter, BARC (barometric altitude rate controller) and flap and gear settings.
_________________
Top
 Profile
 Post subject:
PostPosted: Sun Apr 11, 2004 4:32 pm
Offline
Yup and the Bus has some computers that will not allow the pilot to stall it.
Cat
_________________
Top
 Profile
 Post subject:
PostPosted: Sun Apr 11, 2004 4:54 pm
Offline
Or fly it.
Top
 Profile
 Post subject:
PostPosted: Sun Apr 11, 2004 5:17 pm
Offline
Well, actually you can sort of fly it but if you get to agressive the computers will over ride your input so I guess you can't really fly it. :D :D
But what wonderful colours on those screens............
Cat
_________________
Top
 Profile
 Post subject:
PostPosted: Sun Apr 11, 2004 7:51 pm
Offline
Me sorry, only read the first line about the simple ones.
I would stand corrected, but I'm too tired, so I will sit corrected.
:roll:
_________________
Top
 Profile
Who is online
Users browsing this forum: alex2014, ragequit and 36 guests
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
webmaster@avcanada.ca
AvCanada Topsites List
While the administrators and moderators of this forum will attempt to remove or edit any generally objectionable material as quickly as possible, it is impossible to review every message. If you feel a topic or post is inappropriate email us at support@avcanada.ca .  By reading these forums you acknowledge that all posts made to these forums express the views and opinions of the author and not the administrators, moderators or webmaster (except for posts by these people) and hence will not be held liable. This website is not responsible or liable in any way for any false or misleading messages or job ads placed at our site.
