Garmin 430W
Garmin 430W
Is there a away to select differe I nt annunciations on the 430 when shooting an RNAV approach to different minimums? Example: Switching between LPV and LNAV+V/LNAV minima on the same approach without having to disable WAAS on the SBAS Selection page. I sifted through the manual and could not find anything.
Re: Garmin 430W
Never used a 430 for anything but VFR but on the military grade Proline setup they are differentiated on whether you arm approach mode or not. LNAV/VNAV will automatically annunciate and scale, LPV needs to be armed.
Re: Garmin 430W
SBAS is it as far as I know. And it kind of makes sense as the device is made for actual use and not specifically for training. In actual use it will show you the most precise approach available because that's what you'd want to use. Is there some reason that the SBAS selection isn't satisfactory?
Mark Twain
Mark Twain
