I think you are mistaking a symptom with a cause. Instructing pay at a FTU is low because it’s an entry level position. It’s an entry level position because it’s not a desirable job in the aviation market. For the most part job wise instructing has the appeal of location and depending on the operation, a decent schedule. Those weigh against a lot of negatives, which tend to get worse the higher up in the instructing world. The rise in pay is usually not proportional to the rise in responsibility.
Right now what we’re seeing in the lower end of the flying job market, is if guys are given a choice between right seat in a turbine or right seat in a trainer a majority of them choose the former.
What specifically do they require in terms of instructional technique do you object to? Is there a section of the FIG that is particularly disagreeable?Even more reason for me not to want to instruct for a Canadian flight school is the fact that you must instruct the way T.C. demands you do.
If we had the same regulations the FAA has where any licensed flight instructor can teach PPL's without having to go through the agony and money it costs to get a FTU-OC
I can’t disagree with that, but I doubt if that were the case it would help a lot of people get training, or people start flight schools. There just isn’t a large enough market in Canada. After all, we’re talking about the folks who want a PPL, who aren’t wealthy enough to afford their own airplane, yet not desiring of going to the local established FTU, and have enough money to make it worth your while to serve. In most cases the larger FTUs would fall under part 135 operations, and this change wouldn’t apply to them or change their costs. Regulatory wise, it’s equally onerous.
So in the big scheme of things, while I would applaud such a change, in terms of it improving overall flight training in Canada, it’s impact would be small enough as to not be noticeable.
Would you want to do it as a full time job?I would go back to flight instruction because I enjoy teaching.
That’s nice. So that means you would instruct for cheap?Money would not be the motivating factor for me as I am quite satisfied with my present monetary situation.
