It's ok bud. I still think something is rotten in Denmark. Sounds like just another cash grab to me.Northern Skies wrote:Does not compute......
1. Since you need an atpl to be captain of a crew of 2, he would have been single pilot. (401.31(1), 401.34(1))
2. Under 703, he needs 1000TT/100multi/50 instrument/50 on type/PPC for single pilot IFR (723.86(1))..........
.......ok I give up. I looked into it now and #2 doesn't count for no pax. As well, you said 702, and he could have been doing VFR work. Never mind, I have no valid point......... but I'll post this anyway!!! Aren't the CAR's great?
Cheers!
Multi IFR on Navajo
Actually, number 1 doesn't apply either. You only need an ATPL to be captain on an aircraft which is type certified for two crew. An operator can specify in their ops manual that an aircraft is to be flown with two crew, even if the type certificate only specifies one crew member is required. In that case the captain still only requires a commercial licence.
The 1,000 hrs. and 100 multi with 50 hrs. IMC and 50 on type is for passengers, single pilot IFR - you can do single pilot IFR with considerably less time with cargo, it's up to the company. There is no experience requirement to fly a private machine, just a multi IFR and commercial if being paid. The trick with this guy is that he is VFR and aerial work. He hasn't had to do a PPC either just a PCC I believe.
