Tripleese7 I have no intention of reading all the documents you are quoting for the simple reason I already know how to fly and how to survive.
I am not surprised. The arrogance of the 'older pilots' on here is incredible!
I'd bet a lot of money that not a single soul has read those documents I posted.
When I said "The best way to recovery is essentially let the plane do what it wants to do." I was specifically talking about not forcing the airplane to maintain a heading that is away from where it is actually going. In spin recover and stall recovery you are trying to get the pointy end of the airplane to align with the flight path of the airplane. Using rudder to force the nose
away from the direction of the airplane is counterproductive. That is my point.
Let the airplane fall off to the left and recover on whatever heading it 'falls' onto. As soon as the airplane stalls, do the recovery procedure. The wing drop in a Cessna, if you do that, will be very minimal. As I stated before, when you have a wing drop at the stall it does NOT roll around the longitudinal axis - your heading will change. Heading has nothing to do with aerodynamics!!! F*ck the heading... get the plane out of the aerodynamic stall by getting the nose pointed in the direction the airplane is heading!
I'm not in any way advocating you give control to the airplane to do what it pleases. However, in this ONE instance where you have a wing drop at the point of a stall - forget about getting the nose back to the original heading, get the nose pointing to where the airplane is heading and then recover on that heading.
Again, emphasis is on the fact that a particular heading has
nothing to do with the aerodynamics of flight!
