Approach Ban
Approach Ban
I heard a rumour that AC's new company-wide approach ban is RVR 1800 for a CAT I ILS. Does anyone have details on the specifics or know the reason for the reduction? Has there been a change to the Ops specs?
Re: Approach Ban
The recommended vis for CAT I on the plate is still 1/2sm, 2400 RVR. Is there any point in attempting the approach when the vis gets that low? The CARs may allow it, but what's the use unless you want to practice your missed approach procedures?
Re: Approach Ban
I am going to assume you haven't shot many approaches to minimums. I have shot countless CAT 1 approaches with 1200 rvr (sometimes 3 or 4 a day) and have only missed for not making visual contact a couple of times. And no, I have never busted minimums. This post isn't meant to brag about my superior ability, just simply saying that with good lighting, a stable approach and consistent rvr (not fluctuating down) you will see the runway at minimums a very high percentage of the time with low but legal rvr.goingnowherefast wrote:The recommended vis for CAT I on the plate is still 1/2sm, 2400 RVR. Is there any point in attempting the approach when the vis gets that low? The CARs may allow it, but what's the use unless you want to practice your missed approach procedures?
Re: Approach Ban
No specific reason given, but AC is backing away from conducting instrument approaches in below published visibility conditions. 1800 RVR is the lowest we can do for a CAT I and that is contingent on airport lighting. 75% of published visibility is the lowest we can do on NPA's - and there are a boatload of conditions to meet before we can do that. We do not use 50% published visibility anymore as permitted by TC with the applicable OPS Spec.
I applaud it all and think we should back all the way off to published minimums only just like the entire rest of the planet outside of Canada.
Re: Approach Ban
+1. The minimums are published for a reason.Rockie wrote: I applaud it all and think we should back all the way off to published minimums only just like the entire rest of the planet outside of Canada.
Re: Approach Ban
The rest of the world over charted vis is the minimum...
FAA CAT I min you will see charted is 1800...
AC is simply trying to move to a consistent program. If only Canada TC/NC could get on board on soooo many issues we lag on.
Re: Approach Ban
+2. Honestly by going down to 50% (even 75%) we are just making up for Nav Canada not putting the appropriate infastructure and our nations airports. Doing a CAT I down to 1200 RVR (which I've done too) normally works out okay (JetsGo had some issues in YYC years back), but why should we be satisfied with that? Why not put a little pressure on NC to but some more Cat 2 or better approaches in?
Re: Approach Ban
Using hard numbers gives a common standard, instead of having crews trying rummage through manuals trying to figure out which reduction applies to them. Is RVR 1800? Yes, carry on. Nice and simple. Is this in any way connected to Halifax?
Re: Approach Ban
As I said, no specific reason was given. However when that report finally hits the street I think you will see things in Canada done more in line with the rest of the world from a regulatory standpoint. Otherwise I think pointed questions to the government as to why not are in order.tallyho wrote:Nice and simple. Is this in any way connected to Halifax?
Re: Approach Ban
Have been told very recently that TC intends to get rid of the approach ban and the published vis will be the required vis to attempt the approach.
Re: Approach Ban
it depends what is causing the rvr to be low, if it is blowing snow you can do an NDB with 1 1/2 mile charted vis and land in 1/4 mile RVR before the days of RVOP / LVOP. 1/4 mile in BLSN is completely different than 1/4 in fog. Also the octas of BLSN makes a huge difference a lot of the rest of the world doesn't operate in the types of places we do thats why our rules shouldn't be the same.
Re: Approach Ban
Canada isn't the only place in the world with snow, wind and fog. Are our eyes better than everybody else's that we can see the runway sooner?fish4life wrote:it depends what is causing the rvr to be low, if it is blowing snow you can do an NDB with 1 1/2 mile charted vis and land in 1/4 mile RVR before the days of RVOP / LVOP. 1/4 mile in BLSN is completely different than 1/4 in fog. Also the octas of BLSN makes a huge difference a lot of the rest of the world doesn't operate in the types of places we do thats why our rules shouldn't be the same.
Re: Approach Ban
Not necessarily, but the vis will be called 1/4 mile but you can see the runway from 3 miles back because it's just ground blow. If you see BLSN 2 octa's it's a good sign you will see the runway if it's 8 octas you won't because it's no longer ground blow. You can get 1/4 mile and SKC in the same weather report, yet with our ridiculous Canadian rules if you land it's a violation.
Re: Approach Ban
Navcanada doesnt put in the infrastructure, that is the relevant airport authority. Yhz last year was the HIAA replacing the old system that they couldn't switch ends. If I remember the A320 in question didn't have LNAV/VNAV so an NC approach wouldn't have helped.ZBBYLW wrote:+2. Honestly by going down to 50% (even 75%) we are just making up for Nav Canada not putting the appropriate infastructure and our nations airports. Doing a CAT I down to 1200 RVR (which I've done too) normally works out okay (JetsGo had some issues in YYC years back), but why should we be satisfied with that? Why not put a little pressure on NC to but some more Cat 2 or better approaches in?
There have been times in yhz where i can see the button to 14 from Windsor, but am restricted due to rvr's. RVR 1200's were standard till what 2010, fly the approach to minimums, look up, if nothing seen go around. Pas de probleme!!fish4life wrote:Not necessarily, but the vis will be called 1/4 mile but you can see the runway from 3 miles back because it's just ground blow. If you see BLSN 2 octa's it's a good sign you will see the runway if it's 8 octas you won't because it's no longer ground blow. You can get 1/4 mile and SKC in the same weather report, yet with our ridiculous Canadian rules if you land it's a violation.
Re: Approach Ban
There were 3 landing accidents in a relatively short span with light blue aircraft. (AC YHZ, Jazz YAM, and EVAS YQX) all involving landing in low vis so I'm sure some changes are coming. Hopefully it will be a simpler process instead of the flow charts my company currently uses. The minimums on the approach plate would be a good start!
Let’s Go Brandon
Re: Approach Ban
The minimum visibility published for a non-precision IAP is 1sm, you won't see any NPA's with a vis lower than 1sm by design criteria. Authorization for lower visibility requirements are company specific. I didn't know Jazz and EVAS had that authority.........Inverted2 wrote:There were 3 landing accidents in a relatively short span with light blue aircraft. (AC YHZ, Jazz YAM, and EVAS YQX) all involving landing in low vis so I'm sure some changes are coming. Hopefully it will be a simpler process instead of the flow charts my company currently uses. The minimums on the approach plate would be a good start!
- Pages from TP308E-C6.0.jpg (187.46 KiB) Viewed 7611 times
Re: Approach Ban
I know that Jazz has many GNSS LPV approaches that have a 200 foot DH and required vis of RVR 2600 or 1/2 mile. Depending on lighting the approach can be done down to RVR 1200
Re: Approach Ban
I've never been a believer in the approach ban. It only makes things safer in the same way we could prevent all airplane accidents if we never flew.
In a pre approach ban world - have you ever shot an approach when the FSS or tower was reporting pea soup only to have the runway materialize well above minima? Have you ever shot an approach when the weather was reported as sunshine and lollipops only to find a windscreen full of cloud at minimums? I have had both - and when the weather did not cooperate I went around.
Approach bans don't do shite.
JJJ
JJJ
Re: Approach Ban
Not always. There are conditions for having a CAT I approach with RVR 1800 ft. Centerline lighting (CL), touchdown zone lights (TDZL) and high intensity approach lights are required.altiplano wrote:
If the runway is not so equipped, the minimums are higher, usually 2400 ft.
If the aircraft is equipped with a HUD, they may shoot the approach down to RVR 1800ft, even without CL or TDZL.
They also have Special authorization CAT I and CAT II (SA CAT I/II). SA CAT I is basically a CAT I with 150ft/RVR 1400 minimums, because of the use of a HUD.
Same thing for a SA CAT II. No CL and TDZL required if you have a HUD.
So you see, the FAA also has different approach bans, depending on OPS SPECS and such. The main difference being, the FAA publishes these lower minimums directly on the approach charts. NavCan doesn't.
http://www.faa.gov/other_visit/aviation ... O12002.pdf
