Long haul and dry skin and nose
Dry Guy
Post by Dry Guy »
I wanted to ask how do long haul or even domestic pilots deal with getting dried out from being in pressurized airplanes for so many hours a month? If I do one flight of around 5 hours of more my skin and especially inside my nose will be so dry that I'll even have an occasional nose bleed for days after. I'm nervous I won't be able to work for Air Canada since you are spending many hours a month in very dry air. I drink as much water as possible and avoid caffeine and alcohol. Do any long haul pilots have this problem and do you have any solutions that work for you? Thanks.
aV1aTOr
Re: Long haul and dry skin and nose
Post by aV1aTOr »
Keep on top of moisturizing hands and face, and like you mentioned, drink plenty of water. Like most foreign environments, if your body is only exposed occasionally your skin will react, but more than likely with more regular exposure you will adapt.
My gf bought me this and its amazing. I sleep with it a foot from my face every night.
https://buy.shopfancii.com/products/fan ... 9348145862
All you need is a water bottle.
DP
aV1aTOr
Post by aV1aTOr »
co-joe wrote:My gf bought me this and its amazing. I sleep with it a foot from my face every night.
Never seen one of these... might have to give it a try!
infiniteregulus
Post by infiniteregulus »
Why not just run the shower for a while and steam the room haha
av8ts
Post by av8ts »
infiniteregulus wrote:Why not just run the shower for a while and steam the room haha
I usually fill the tub with hot water on layovers
AF1000
Post by AF1000 »
I always have a bottle of Saline Spray. Works like a charm. I've asked my CAME and there are apparently no long term side effects to using it.
JBI
Post by JBI »
I did this once and set off the smoke detector :shock: At least it was at a decent time in the afternoon.
AF1000 wrote:I always have a bottle of Saline Spray. Works like a charm. I've asked my CAME and there are apparently no long term side effects to using it.
Have to try that. I tried that Secaris stuff from an airport news store. Works ok. Better than a nosebleed.
GQ4
Post by GQ4 »
http://pendopharm.com/wp-content/upload ... el-BIL.png
Apply a couple of times per day with a q-tip. Works great.
Dry Guy
Post by Dry Guy »
Thanks for the tips guys. That Secaris looks like just the ticket. I'll have stock up next time I'm through a Canadian airport.
Return to “Air Canada”
