The attributes of the 737MAX joining the AC fleet?
Moderators: ahramin, sky's the limit, Sulako, North Shore
Message
Author
yycflyguy
Re: The attributes of the 737MAX joining the AC fleet?
#26 Post by yycflyguy » Tue Jan 09, 2018 9:42 am
Level Change wrote:
Mon Jan 08, 2018 10:19 am
It takes forever to start the new Leap engine. Anyone who has flown Garretts will understand the concept of having to spin prop blades after shutdown. The Leap requires the same on start up. It motors for 90 secs to stabilize internal temps before we can add fuel and ignition to the mix. Typically, another 90 secs from light off to start sequence termination. Add another 3 minutes to stabilize temps before applying takeoff thrust and you have 6 minutes from start to ready for takeoff. There may not be as many single engine taxi outs as a result.
Good!
totalflyer
#27 Post by totalflyer » Tue Jan 09, 2018 10:29 am
This would explain what happened the other day with a WestJet MAX coming out of deicing... they had to by pulled out of line by ATC because they still needed 3 minutes before they could depart and failed to inform them before getting to the holding bay of 06L... sounds like a bit of a pain especially if timing is critical for hold-over times etc.
rudder
#28 Post by rudder » Tue Jan 09, 2018 12:34 pm
Deicing at YYZ is live spray so engines would already have been running.
There is a delay after spray for bleeds/packs. I think 2-3 minutes. There is also a requirement to do an engine run above idle prior to departure if engine anti-ice was selected on during taxi. Most operators do this in position on runway immediately prior to take off (advance thrust - wait - select TOGA).
Not sure why the WJ MAX would have needed extra time.
#29 Post by altiplano » Tue Jan 09, 2018 1:04 pm
Maybe they decided to do a single engine taxi to deice? Started the other on the way out and had to wait to get it warmed up?
confusedalot
#30 Post by confusedalot » Wed Jan 10, 2018 5:46 pm
I did some sim testing work on the max, and yes, you need to motor the engine before fuel introduction until the plane tells you to, which takes quite a bit of time. (something about straightening out the composite alloy engine shaft as I recall) So the actual start sequence is the culprit, not the engine warmup.
So I am guessing that a single engine taxi routine may become impractical depending on how long you have until takeoff? Only after the engine is started can you start the warmup time.
fruitloops
#31 Post by fruitloops » Sat Jan 13, 2018 6:57 pm
Any plans for some 737s to be based in YVR as well?
confusedalot
#32 Post by confusedalot » Sat Jan 13, 2018 9:15 pm
Don't you need to be a senior 777 left seater just to live in a basement apartment in YVR? :lol:
I dunno, just making light of the situation.
islandguy
#33 Post by islandguy » Tue Jan 16, 2018 11:41 am
Nothing posted out here yet. I think most suspect it's only a matter of time, but most of us are hoping the eastern boys'll keep the New Shiny to themselves and saddle us with the bulk of the old 320 fleet. We like being left to ourselves ;)
aV1aTOr
#34 Post by aV1aTOr » Tue Jan 16, 2018 4:53 pm
Couldn't have said it better.
"Wow that *ahem* 'new' 737 sure is nice! Why don't you guys keep them all??"
Wheels
#35 Post by Wheels » Tue Jan 16, 2018 6:14 pm
Has it come down to direct entry 737 Captains? Or is this just a rumour.
Gino Under
#36 Post by Gino Under » Tue Jan 16, 2018 7:01 pm
Interesting comments on the Max.
Just curious as to the number of ‘memory items’ on the MAX?
Isn’t there something missing in this day and age when a supposedly modern, improved aircraft like the MAX is missing a basic EICAS system, like the one found on the B767 and 757? Perhaps it was left out because of ‘common’ type rating issues enjoyed by the FAA and not Transport Canada. I never could figure that out.
…and how advanced is the 777 and 787 ECL? I’d imagine something like that in the MAX would be well received by all MAX pilots.
I remember having to partially stand up to reach the overhead NAV panel to switch the IRSs to NAV. Is it still like that in the MAX? After all these years, imagine still having to do that? Ergonomics wasn’t as well developed in 1964 as it is today so I guess they get a pass.
Flew in the cabin of an Air Canada 787 to Europe last summer. First time on one I might add. That had to be the loudest, longest engine start I ever heard. Only the L1011 came close. But it's nice to know FADEC recognizes rotor bow during an engine start. You'll get used to GTF engines. They'll put an end to single engine taxiing. Watch.
It’s disappointing that Boeing wasn’t willing to update and upgrade the B737 in their rush to market something ‘acceptable’ as a more competitive offering to stave off Airbus and Bombardier. I think it was a bad move by Boeing and judging by the numbers of MAX derivatives sold to date at giveaway pricing, in about 15 years or less, when they will have to deal with greatly depreciated MAX book values, Boeing will have a rather large number of angry customers on their hands. But hey, live for the moment.
Enjoy whatever aircraft you're flying for whatever it is, it's the best. (Keep the blue side up)
Gino Under :partyman:
confusedalot
#37 Post by confusedalot » Tue Jan 16, 2018 8:26 pm
In case no one noticed, the only reason why a 737max does not have a 777/767/757 sort of cockpit with eicas and all, are because;
Primarily to keep the plane as a single type rating for the likes of Southwest, American, et al...so no initial type rating required. An NG guy gets into a max with about, what, 2 hours of extra ground training? I flew the NG, I did sim acceptance with the max, it's the same airplane as far a a pilot is concerned and every NG pilot out there is comfortable immediately.
Second, the new max investment by Boeing is minimal, once again, same as any other 737 with a bit of lipstick, new engines, etc...
#38 Post by altiplano » Tue Jan 16, 2018 10:38 pm
What are we complaining about here?
Stretching to reach a switch that you really only put on when you get there and turn off when you leave? (standing up)
A few memory items?
Paper checklists?
So hard done by...
Fanblade
#39 Post by Fanblade » Tue Jan 16, 2018 11:17 pm
Rumour. Not factual
yycflyguy
#40 Post by yycflyguy » Wed Jan 17, 2018 10:05 am
Same number of memory items as the 767. Drills are very similar. No EICAS but Boeing QRHs are all essentially the same. The overhead panel is an abortion and many of the "switches" could have been automated but kept with the 50s technology. Rumours are that the engines are not living up to the performance that Boeing promised and bulk loading bags is absolutely absurd. C'est la vie. C Series come in 2019 :)
Return to “Air Canada”
