Another one.
- Old fella
Another one.
Which is the best to fly A330 or B767 - or does it really make any difference.
Re: Another one.
I haven't flown the 67 yet but I'd vote for the A330: It has a table.
They are two different generation of aircraft, quite different as far as such things go.
Re: Another one.
A330 pays slightly better.Old fella wrote:Which is the best to fly A330 or B767 - or does it really make any difference.
B767 has more diverse destinations.
A330 flies you.
B767 you fly.
A330 is a technological marvel.
B767 is retarded.
- Old fella
Re: Another one.
"A330 is a technological marvel"
Why did AC unload the A340 then, isn't the A330 same as the A340 sans 2 engines. Was it due the A340 drank fuel with it's extra engines but better range - correct me if I am wrong.
Re: Another one.
Unless AC is planning on adding A350's to the fleet (unlikely) the era of the Airbus wide body at AC will be coming to an end. Makes no economic or operational sense to support such a small number fleet type. Yes, there is commonality with the Airbus narrow body fleet, but change may be coming in that regard as well. Perhaps the two announcements will be combined later this year.
Re: Another one.
This summarizes it perfectly. One sidenote however, and this is no small thing: In a Boeing you eat, but in an Airbus you dine. Never underestimate the tray-table.yycflyguy wrote:
A330 flies you.
B767 you fly.
B767 is retarded.
- Old fella
Re: Another one.
The tray-table for dining huh, a spot to put yer glass of Classified Left-Bank Bordeaux - Chateau Margaux then !!aV1aTOr wrote:This summarizes it perfectly. One sidenote however, and this is no small thing: In a Boeing you eat, but in an Airbus you dine. Never underestimate the tray-table.yycflyguy wrote:
A330 flies you.
B767 you fly.
B767 is retarded.
Re: Another one.
Indeed.aV1aTOr wrote:This summarizes it perfectly. One sidenote however, and this is no small thing: In a Boeing you eat, but in an Airbus you dine. Never underestimate the tray-table.yycflyguy wrote:
A330 flies you.
B767 you fly.
B767 is retarded.
