I have seen this issue come up in past discussions but has anyone determined a way to remove attachments to make room for updated resumes when the file limit of 5 documents has been reached on Air Canada's Job Application site?
I find it kind of hard to believe that once you reach 5 you don't have the option of removing older files.
Any insight would be appreciated.
Uploading Resume to Air Canada - Limit Reached
- Flying Low
Not positive...but I believe someone mentioned you have to upload a document with the same name ("Resume" for example) and it will replace the one already there.
I think that's way LJ, try copy pasting the name from their website on your file (in you PC) and make sure the space after the name is deleted
ex: On AC's wensite, your resume appears as: LJDriver CV05.doc copy paste to your file in order to rename it, make sure that CV05 has no space after it.
I had the same problem with Bombardier's website.
In the business world, the rearview mirror is always clearer than the windshield...W. Buffett
