WJ and ETOPS
Moderators: lilfssister, North Shore, ahramin, sky's the limit, sepia, Sulako, I WAS Birddog
pika
WJ and ETOPS
Post by pika »
Anybody have an idea when 180 minutes might be happening?
Post by -700 »
September.
If it's a Boeing, it's going!
RB211
Post by RB211 »
September? How can you be so sure? Isn't it up to TC. Do you have an Ops spec for 90 or 120 yet? Generally it is required to reach 180 in stages.
Is the whole -700 fleet going to be maintained to ETOPS criteria or will it be a number of designated a/c?
Canus Chinookus
Post by Canus Chinookus »
It'll be the fall, rest assured.
pika
Post by pika »
Care to make a friendly wager on your "sure thing"? I suggest it won't be the fall...
Canus Chinookus
never bet on anything on aviation... however i will take a bet on when WJ get's 120 minutes! ;)
Blastor
Post by Blastor »
It's been September since last march!
Post by -700 »
Just got off trainig, we are currently approved at 120 mins but it gets us nowhere. All NG's 600,700 and 800's will be ETOPS certified although only 7's and 8's will have the range. 600's will not be comimg with winglet's although they may be added later.
I was suprised to learn there are 21 operator's currently operating 737 NG's for ETOP's flts. TC was happy with our program and a/c reliability both at WJ and world wide.Boeing is currently sending TC all the trend reports and data and the projected date for 180 is September.
I'm sure all of you ops and flt ops people will be on training soon or already have there is a lot of intresting info in there and future plans. Looks cool.
Canus Chinookus
awww, you spoiled my 120 minute bet! :p
pika
Post by pika »
Can you guys/gals doing your ETOPS ground school confirm or deny that the NG's will need the APU running while in the ETOPS sector?
Post by -700 »
True. As per TC.
Rebel
Post by Rebel »
Hmm I don’t think so, the APU has to be running from the start of the flight because of the possibility that it won’t start in flight. After the ETOP’s portion of the flight is finished then its okay to shut it down.
pika
Post by pika »
That is a risk the operator will have to decide on. It has to be running through the ETOPS sector, not anytime before. If it doesn't start when you get to the ETOPS sector you have to turn around.
jetpilot
Apu ?
Post by jetpilot »
TC request the APU to run? :roll: what is the max altitude the apu can run on the NG? Allied Signal GTCP 131-9B is 410 right? but can you apply Power and bleed? sound strange to let the apu run for fun!
cheers
pika
Post by pika »
APU runs just in case... No RAT/HMG (I think?) on an NG so you need the APU ready to pick up the electrical load if you lose one source. Bleed will not be required. Some 757's with a low voltage HMG also need to have the APU running in the ETOPS sector.
Post by -700 »
TC requests that the APU run for the ETOPS segment. Westjet has bettred it and said that they will run the APU from begining to end, obviously thinking the same, what if it doesn't start. Althought the APU's have incredible reliability. All this from the horses mouth.
pika
Post by pika »
TC requests it because Boeing demands it.
Post by -700 »
Boeing does not make ETOPS regs, neither can they demand anything from a regulatory body. They can have specs, limits, recommendations whatever but the decision of what needs to be done for an ETOPs flt, a Cat 2 or Cat 3 approach rests with TC.
Wityh the current reliability of the CFM's Boeing would most likely go in the other direction to show a cost savings on fuel burn.
Froggy
Post by Froggy »
Pika, Listen to -700
He/She is obviously an AME for westjet as I am. We have had the training and know what's required and so on. Westjet is choosing to run the APU's from the start of the flight at least until the ETOPS portion is complete at which point it's not worth it to turn it off only to start it back up again on the ground! It only burns 250 PPH. and for gen info, APU is good for elec. to 410 and pneu. at 370 if i remember correctly. Only elec is required as windmilling should suffice for restart and one engine provides more than enough bleed for pressurizing the cabin. :wink:
RB211
Post by RB211 »
Couple of questions for any WJer's that care to answer:
When did WJ receive 120 min approval?
Are centre fuel tanks installed or planned to be installed?
Will all -700's be maintained according to the ETOPS maintenance program or just a portion?
Thanks in advance.
Return to “WestJet”
