MP tells you nothing about torque. The MP at this precise moment is about 29.94" and the torque is ... zero. Go figure.CpnCrunch wrote:MP is essentially the torque,
How do I know the torque? Because I know the power: 11GPH is close to 55% power when LOP, so you can work out how the torque varies with RPM. If the RPM goes down the torque goes up in mathematical proportion. Hell, that's how the constant speed unit reduces the RPM, by twisting the blades to absorb more torque so the engine slows down.
Someone asked about how do I know what the fuel flow is... there's a calibrated transducer and digital display, aside from the analogue pressure gage.
Someone posted a link to it earlier in this thread. This engine isn't in it.SuperchargedRS wrote:Not sure about your engine, but on my 520 continental came out with a bulletin saying not to cruise below 2300, some words like "catastrophic" and "failure" were used.
Maybe they should have tried 2050/27.5" then. 450 hours past TBO on this one so far, and still going. I'll let you know what happens.jschnurr wrote:Back several years ago, a certain flight school in Southern Ontario thought that to save fuel, they would run their fleet of Bonanzas at 2200/22" instead of 2300/23". It worked fine for a while, but after several hundred cumulative hours across the fleet and 3 catastrophic engine failures later, it was determined that the lower power setting was setting up harmonics within the engine that caused microscopic cracks to grow until failure..
Yes, my whoops, sorry.B208 wrote:Power is related to the mass of air through the engine. The mass of air is a function of volume, temperature and (manifold) pressure.volume of air pumped and
