Unserviceable Equipment C172
Re: Unserviceable Equipment C172
Well then unless you decide to test them, you could complete hundreds of day VFR flights and not know they were U/S.
True, but the same could be said for a failing exhaust valve, and I don't think any of us would defer that one.
The 172S from 1998 with steam gauges has the lighting and transponder as -S, too, as one might expect.
I’m going to guess that somewhere in the long list of parts of 14CFR23 that apply only to G1000 equipped 172S models, is a requirement for a transponder, and strobes. Hence they become required for airworthiness in that aircraft, without doubt.
Certification Basis (cont’d)
Additions for the Garmin G1000 Integrated Cockpit System (ICS) Only: Additions for the Garmin G1000 Integrated Cockpit System (ICS) Only:
14 CFR 23.303; 23.307; 23.601; 23.1163(a); 23.1367 and 23.1381 as amended by Amendment 23- N/C. 14 CFR 23.1589 as amended by Amendment 23-13. 14 CFR 23.771(a) as amended by Amendment 23-14. 14 CFR 23.607 and (Electrical System) 23.1309(a)(1)(2), (c) as amended by Amendment 23-17. 14 CFR 23.1301; 23.1327 and 23.1547(e) as amended by Amendment 23-20. 14 CFR 23.1501 and 23.1541(a)(1), (a)(2), (b)(1), (b)(2) as amended by Amendment 23-21. 14 CFR 23.603 and 23.605 as amended by Amendment 23-23. 14 CFR 23.1529 as amended by Amendment 23-26. 14 CFR 23.561(e); 23.1523; 23.1581(a)(2); and 23.1583(a), (c), (d), (f) as amended by Amendment 23-34. 14 CFR 23.301 as amended by Amendment 23-42. 14 CFR 23.1322; 23.1331 and 23.1357(a)(b)(c)(d) as amended by Amendment 23-43. 14 CFR 23.305; 23.773(a)(1), (a)(2); 23.1525 and 23.1549 as amended by Amendment 23-45. 14 CFR 23.1303(a)(b)(c)(f); 23.1309(a)(1)(i), (a)(1)(ii), (a)(2), (b)(1), (b)(2)(i), (b)(2)(ii), (b)(3),(b)(4)(i), (b)(4)(ii), (b)(4)(iii), (b)(4)(iv), (c)(1), (c)(2)(iii), (c)(3), (d), (e), (f)(1); 23.1311; 23.1321 (a)(c)(d)(e); 23.1323(a), (b)(1), (b)(2), (c); 23.1329 (g)(h); 23.1351(a)(1), (a)(2)(i), (b)(1)(iii), (b)(2)(3), (c)(4), (d)(1); 23.1353(a)(b)(c)(d)(e); 23.1359(c); 23.1361; 23.1365(a)(b)(d)(e)(f) and 23.1431(a)(b)(d)(e) as amended by Amendment 23-49. 14 CFR 23.1325(a), (b)(1), (b)(2)(i), (b)(3), (c)(d)(e); 23.1543(b)(c); 23.1545(a), (b)(1), (b)(2), (b)(3), (b)(4); 23.1553; 23.1555(a)(b); 23.1563(a) and 23.1567(a) as amended by Amendment 23-50. 14 CFR 23.777(a)(b); 23.955(a)(2); 23.1337(a)(1), (a)(2), (b)(1), (c) as amended by Amendment 23-51. 14 CFR 23.1305(a)(1), (a)(2), (a)(3), (b)(2), (b)(3)(i), (b)(4)(i), (b)(5), (b)(6)(i) as amended by Amendment 23-52. 14 CFR 23.901(a)(b) as amended by Amendment 23-53.
This document is somewhat relevant to lighting:
http://rgl.faa.gov/Regulatory_and_Guida ... -07-09.pdf
Interesting reading. What a gong show. There really should be a law against laws so complicated that the regulator makes mistakes. Something along the lines of if the FAA makes a mistake regarding their own rules on lights, no more rules on lights! EVER! Do what you want!
I can’t get my head around why lights would be required if you have a G1000 but not if you have steam gauges. Same for the 182. And that document doesn’t help.
It's to warn other pilots that the G1000 pilot is probably not looking outside but playing with all the toys in the cockpit
Something to think about. What sections of a POH are specifically "FAA APPROVED"?
Section 2 (Limitations) and 9 (Supplements)
Is that correct? Limitations in section 2 of a POH are mandatory, but when it comes to an Approved Flight Manual, such as the newer 172’s including the one under discussion have, I thought the whole manual is approved, hence the name.
CESSNA SECTION 2
MODEL 172S NAV III OPERATING LIMITATIONS
INTRODUCTION
Section 2 includes operating limitations, instrument markings, and
basic placards necessary for the safe operation of the airplane, its
engine, standard systems and standard equipment. The limitations
included in this section and in Section 9 have been approved by the
Federal Aviation Administration. Observance of these operating
limitations is required by Federal Aviation Regulations.
INTRODUCTION
Those limitations are approved. I don’t interpret that as meaning that the FAA hasn’t approved the contents of the rest of the “Approved Flight Manual”, including the equipment list. The notification of which equipment is required doesn’t constitute a limitation.
Another disadvantage of having a G1000 Cessna: since the avionics are tied into the TCDS, your upgrade options are somewhere between 1 and 0. In the steam gauge Cessnas you could install any TSO'd avionics you like, for the next 100 years, with a dozen or so glass panel options if that's your fancy.
If you have the G1000 you had better pin your hopes on the Garmin G1000 NXi being offered as an upgrade by Cessna.
Slight topic drift: how much would a new 172 cost with a G5 and GFC 500 instead of the G1000 and GFC 700?photofly wrote: ↑Tue Feb 20, 2018 2:43 pm Another disadvantage of having a G1000 Cessna: since the avionics are tied into the TCDS, your upgrade options are somewhere between 1 and 0. In the steam gauge Cessnas you could install any TSO'd avionics you like, for the next 100 years, with a dozen or so glass panel options if that's your fancy.
