Is it really turning to ice
This is not really aviation related except for the fact that I tried it once while up north and I was up north due to a flying job.
It is the idea that at -40, throwing a cup of water in the air turns to ice before it hits the ground. When I tried it, as far as I was concerned the water was not frozen when it hit the ground.
So watch the video....
https://edition.cnn.com/2018/12/07/asia ... index.html
The steam is coming from the hot water but as far as I am concerned, I can see the water itself hitting the ground. And why not use cold water? I guess the steam is not as impressive.
But maybe I did it wrong. Has anyone else tried this.
Re: Is it really turning to ice
I tried this with my wife in Sioux Lookout last year with an outside temp of -38 C. The spray breaks up into very fine droplets and the cold/dry air makes the steam very dramatic, but there are still liquid drops hitting the ground.
Yes, it is also evaporating and some would still fall as a liquid as you're just throwing it out of a cup. It works best below -40 and with water just from boiling.
Pump it and aerate it and you've got yourself a snowmaker.
If you use a super soaker full of hot water it’s a neat effect too
If it’s not solid by the time it hits the ground, you’re just not throwing it up high enough.
Anything you drop out of an airplane at 30,000 feet is going to freeze for sure. So just throw harder.
I think you're missing condensation nuclei.
Good point. Shouldn’t it supercool and turn solid he instant it hits the ground then, like freezing rain?
Condensation nuclei is required to go from gas to liquid, not the other way around and nothing to do with liquid solid state changes.
I don't know if it's turning to ice or not, but it definitely looks nice when it's really cold outside and the water is very hot. Something interesting is happening there. We can debate exactly what but it's still fun.
I don’t agree. Supercooled liquid water often exists below the freezing point, until something kicks off the crystallization process.
A supercooled liquid water droplet is a liquid. It has already condensed from water vapour to liquid around a condensation nuclei and then gets cooled below freezing.
I get what you are saying photo, but for the sake of trying to speed up the process, I believe condensation nuclei would help. Below is a quote from the wiki article on snow making at ski resorts. No idea what an ina protein is though. I was thinking of dirt or dust....or even silver iodide like weather mod uses.
Ice nucleation-active proteins
The water is sometimes mixed with ina (ice nucleation-active) proteins from the bacterium Pseudomonas syringae. These proteins serve as effective nuclei to initiate the formation of ice crystals at relatively high temperatures, so that the droplets will turn into ice before falling to the ground. The bacterium itself uses these ina proteins in order to injure plants.[9]
