Flying long distances in T effect ( Ground effect. ).
How many pilots here have flown for long distances over water using T effect to extend range?
Re: Flying long distances in T effect.
Are we talkin' ground effect here CWE? Yes, many times crossing Lake Simcoe, bot over the water in the 'boat, and over the ice in various wheel planes. I did notice that it was hard to achieve in the 182 amphib, as I was just not that comfortable getting the floats that close to the water or the ice at cruise speed. Both the 'boat and the 150 will pick up about 5 MPH when cruising in ground effect.
Yes T effect over water is ground effect which is roughly half the wingspan of an airplane.
I used it quite often during long over oceans flying and for the airplane I was flying it was fifty feet above the water and is quite easy flying at that height.
By the way when flying in the ITCZ and penetrating really active frontal thunderstorms I flew in T effect to avoid loss of control in the violent up and down air currents at altitude. Penetration of most frontal storms does not take very long as long as you penetrate perpendicular to the front.
The first time I used that method to fly through the ITCZ with tops over seventy thousand feet was in 1974 between Panama and the coast of Ecuador.
And in T effect it is quite safe.
- Daniel Cooper
I would not penetrate thunderstorms at 50 feet that's for sure.
Why not, please explain why you would not.I would not penetrate thunderstorms at 50 feet that's for sure.
By the way I should probably elaborate on this part.
When approaching an active frontal system in the ITCZ at very low altitude you can avoid most of the really bad parts of the front by avoiding the heaviest rain directly under the actual thunderstorm buildups that are occurring.
How much experience do you have flying in the ITCZ ?
Cliff Jumper
Shooting three pointers is pretty safe if you're Stephen Curry.
I'll stick to lay ups, thanks.
I suggest everyone else does the same.
So THAT is what AF447 was trying to do! Mystery solved
I can see this being popular back in the canso days.
There's just way too much risk for me thanks.
switchflicker
Where does the T come from when talking about ground effect?
"I'd rather have it and not need than to need it and not have it" Capt. Augustus McCrae.
Re: Flying long distances in T effect ( Ground effect. ).
For sure each and every pilot should not attempt to fly in any area of flying they are not comfortable with, that is good decision making on your part.There's just way too much risk for me thanks.
However in that flying the PBY was something that I had a lot of experience in and long over water flights were part of the type of flying I did when delivering airplanes I never ever started a flight without making sure I was doing it as safely as possible and the simple fact that I never ever damaged an airplane including PBY's are evidence that my risk evaluation was correct.
The PBY is a relatively rare airplane today but there was a time they were used in 705 operations and actually did a good job for the kind of flying they were built to do. Austin Airways used them for many years flying a scheduled airline service from Timmins Ontario to Baffin island in the NWT IFR.
In fact that was where I started flying them in 1968.
Looking back they also allowed me to make relatively good money, a thousand dollars a day may not be a lot to some people but I was satisfied with it.
Cliff Jumper
Ah yes, the old "I've been doing this for a million years, and I've never crashed, so it's not risky". That's a fundamental error to be avoided during risk analysis. Can you imagine if we actually managed risk that way? We'd never change anything until someone died.
But, back to the topic on hand,
Cruising at 50 feet anywhere is more risky than cruising at 5000 ft.
Full stop.
Doesn't matter who, what, where or when.
Avcanada is a good way to pass time and I have lots of spare time so I will entertain myself responding to your comments cliff jumper.
If that is true then how did I fly for over half a century for a living accident and regulatory charges free, was it just pure luck?
You think trying to penetrate an active frontal system in the ITCZ in an airplane like a PBY at 5000 feet on instruments is safer than at the surface where the turbulence flattens out and becomes lateral rather than vertical?
And as a bonus you have visual reference with the surface and thus the ability to fly through the less violent rain and turbulence.
We disagree that is obvious, my opinion is based on many years of that kind of flying in the ITCZ where the most violent storms on earth are a common occurrence.
How much experience do you have in that area?
Are you suggesting my risk management was lacking cliff jumper?Ah yes, the old "I've been doing this for a million years, and I've never crashed, so it's not risky". That's a fundamental error to be avoided during risk analysis. Can you imagine if we actually managed risk that way? We'd never change anything until someone died.
Really?But, back to the topic on hand,
Full stop.
Since you admitted in the icing topic that you almost crashed taking off with in a DC3 covered in frost, and since you are now advocating flying under a thunderstorm 50 ft AGL, I'd say luck was a pretty big factor yeah...
... but to be fair, I'm sure it is a big factor for a lot of other pilots as well.
If you read my comments on the DC3 incident I am sure I said it was a very light trace of frost that I thought would not have any affect on flying an empty airplane, I was wrong and learned a good lesson from it.Since you admitted in the icing topic that you almost crashed taking off with in a DC3 covered in frost, and since you are now advocating flying under a thunderstorm 50 ft AGL, I'd say luck was a pretty big factor yeah...
As to flying under a thunderstorm line at fifty feet above the water what altitude would you fly through the front?
Most people would say no altitude. Either go around it or stay home.C.W.E. wrote: ↑Wed Jan 23, 2019 10:01 pmIf you read my comments on the DC3 incident I am sure I said it was a very light trace of frost that I thought would not have any affect on flying an empty airplane, I was wrong and learned a good lesson from it.Since you admitted in the icing topic that you almost crashed taking off with in a DC3 covered in frost, and since you are now advocating flying under a thunderstorm 50 ft AGL, I'd say luck was a pretty big factor yeah...
Meatservo
digits_ wrote: ↑Wed Jan 23, 2019 9:42 pmSince you admitted in the icing topic that you almost crashed taking off with in a DC3 covered in frost, and since you are now advocating flying under a thunderstorm 50 ft AGL, I'd say luck was a pretty big factor yeah...
There are two of you guys in this silly disagreement, and only one of you has any experience in heavy flying-boats that go 90 knots and cross oceans, including the frontal systems of the doldrums. I'm guessing that ain't you, digits.
As for you, Ant you do understand he's talking about a region of the ocean that's probably beyond the point of no return for a piston-driven boat? Believe it or not, a lot of aviators in the round-engine era operated on the "no return" side for much of their careers.
I have never had to cross an ocean in an old boat, either, but just from flying other old, slow machines, I can tell you that I'd rather fly between the rain shafts and maintain visual contact with the surface than get torn apart trying to penetrate a front in the intertropical convergence zone at 5000'.
Navigating oceans is not the same as flying over them in a jet. Long distance ferrying in unpressurized piston-driven boats meant you were as much a navigator and a sailor as an aviator. Young people who operate aeroplanes in this day and age can rarely be labelled "any of the above". Your criticism of .'s experience is naive and misplaced.
Absolutely, but you wrote yourself that you were very close to crashing the airplane. If the plane won't fly, then no superhuman flying skills are going to save you. You can't brag about your risk management skills and your succesful 50 year flying career, if at the same time that career could have been over after XX (5? 10? 15?) years because you almost crashed and only survived by sheer luck.C.W.E. wrote: ↑Wed Jan 23, 2019 10:01 pmIf you read my comments on the DC3 incident I am sure I said it was a very light trace of frost that I thought would not have any affect on flying an empty airplane, I was wrong and learned a good lesson from it.Since you admitted in the icing topic that you almost crashed taking off with in a DC3 covered in frost, and since you are now advocating flying under a thunderstorm 50 ft AGL, I'd say luck was a pretty big factor yeah...
I'd wager that most pilots have had very close calls at some point in their career. The difference is, they don't go bragging about their accident free career, because they realize they've come close a couple of times, and some degree of humility would be appropriate.
Sure, nothing wrong with flying between the thunderstorms under the cloud layers to find the worst areas and avoid them. I wouldn't do it at 50 feet though. And here's the thing: if you ferry those planes, and you have to resort to this 50 ft AGL flying to survive, can you really claim that your superior judgement and flying skills are the reason you survived? Or could it be that you were bloody lucky at that point that nothing bad happened?Meatservo wrote: ↑Wed Jan 23, 2019 10:14 pm
Your comments are so appreciated meatservo you will never know, what you described is 100% accurate.There are two of you guys in this silly disagreement, and only one of you has any experience in heavy flying-boats that go 90 knots and cross oceans, including the frontal systems of the doldrums. I'm guessing that ain't you, digits.
Sometimes I really wonder why I keep posting here and have to put up with negative comments from people who obviously have no clue about the subject they are commenting on.
So it is nice to have a professional pilot jump in and back me up.
Thanks!
. E.
This thread was started to point out the advantages of flying in ground effect over the ocean to increase range and one of the obvious added advantages is increased safety when penetrating active weather fronts.Sure, nothing wrong with flying between the thunderstorms under the cloud layers to find the worst areas and avoid them. I wouldn't do it at 50 feet though. And here's the thing: if you ferry those planes, and you have to resort to this 50 ft AGL flying to survive, can you really claim that your superior judgement and flying skills are the reason you survived? Or could it be that you were bloody lucky at that point that nothing bad happened?
Digits your comments are insulting, however based on your apparent ignorance of the subject I will not bother replying to anything you post here from now on.
To get back on track here. Do you recall what kind of fuel savings you got by flying in ground effect? I’ve done plenty of flying in ground effect but it was more to do with being young and dumb or impressing girls than saving fuel.
First the russians got it right with their WIG program and proved it's value. New weapon technology trumped that.
Getting back to the situation here it's like most things, the current generation(s) are applying their standards to judge. The one big thing that they are missing, the lack of technology. What weather reporting or forecasts, navigation and the list goes on. Risk management, really it was taking off into the vast unknown and at the very best you had some wx reports and possibly if the HF has signals you might know wx en route at a few stations but in between it would be a crap shoot and all you can do is deal with what is served and not have the luxury of turning back. It was a different age so don't judge using what you perceive as knowledge and base your standards on, especially you have only been flying since the introduction of GPS. Respect history and learn from it. Jsssszus a pig boat had 24 hours of fuel even today how current are forecasts if you are arriving after a flight like that
http://www.blackair.ca
- Daniel Cooper
Couple years in Africa and a year in SE Asia. Actually it was the most predictable weather of my entire career.
ruddersup?
I can say that there is a very strong comfort factor flying at 50 ft. over the water with a float plane if the waves aren't a factor.
Endless runway, little traffic, smooth air and the engine just sounds better. Now taking a leak might be tricky and glassy water, fog or haze, hmmmmm.
., well done. Interesting how much flying airmanship has changed and now they're flying computers. Different world now but is it safer only because the equipment is better and makes up for the lack of flying skills?
Digits? With all do respect, I've seen you do the most ridiculous thing imaginable with an aircraft and survive, although you did by luck only, IMHO.
Tone down your rhetoric.
Absolutely, luck is a big factor if you do some non-everyday flying. I've never disputed that. I also don't go bragging about surviving and not crashing in every topic I post.ruddersup? wrote: ↑Thu Jan 24, 2019 9:11 am Digits? With all do respect, I've seen you do the most ridiculous thing imaginable with an aircraft and survive, although you did by luck only, IMHO.
I also have no problem with people attempting adventurous and/or riskier flying, that is their choice. But even the greatest airshow pilot will die if their elevator locks when they are low level vertically headed down to the runway (it has happened). And from the people I've talked to, most of them are aware of that and don't brag about an incident free career, even though their flying is risky, because they are aware just how lucky they are.
You don't find it funny that a pilot who admits he almost crashed a plane covered in light frost, is the same pilot that brags about a 50 year crash free career? It's great that nothing bad happened, and I don't wish crashes upon anyone. But if the difference between a crash after 10 years of flying or a 50 year accident free career is luck, then I think you forfeit the right to legitimately brag about how your experience and skills lead to an accident free career. That's all.
