This entire debate started because you don’t think they should have left the thrust up. They needed the thrust to climb, airplanes don’t climb on pitch trim alone.
It is a note providing clarity on the procedure, not the procedure itself. You posted it yourself, it clearly has operating instructions and then a note to provide expanded information. I have no how you can argue this, you posted it.. it says note...
And they did exactly that, they used the control column and the electric trim as needed. Which they did. They clearly followed the procedure perfectly and believed the procedure would allow them to trim the aircraft manually, which they tried and failed.boeingboy wrote: ↑Wed Oct 23, 2019 9:16 pm As does the NNC. if you look at the little words in step 2 after disengage autopilot - it says to control airplane pitch attitude manually with control column and main electric trim as needed then use the stab trim cutout switches.
It's basic airmanship 101 to trim out control forces. I think it's one of the first lessons every pilot getting their PPL learns. It's what every pilot does in all flight phases - no matter what they fly.
Common sense is following a procedure believing that it will allow you to fly the aircraft safely back to the ground. This crew did that and Boeing failed them.
