RAIC Passes
RAIC Passes
Hey all -
I'm a flight paramedic looking to work for two different aeromedical companies at two different airports. Anyone know of a way to do this? The pass offices suggest I can only hold one RAIC at a time and as they are different companies, a CANADA pass won't work either! Ideas?
Re: RAIC Passes
You will need a multi employer pass but I have only seen those for ground staff working at a single airport. Speak to both your employers and ask the pass office at both airports what they suggest.
Re: RAIC Passes
Why would a CANADA pass not work?403hermit wrote: ↑Wed Nov 20, 2019 7:46 am Hey all -
Re: RAIC Passes
I've seen them for contract pilots, but they were both companies at the same airport (YYC). A RAIC is a RAIC, I don't see why they have to say the companie's name on them. If that's the issue, then get one company on the RAIc, and get the other company to provide picture ID that shows you work there. If you have a need, and a right to be there, and can prove that you should be G2G.
Re: RAIC Passes
I have never seen one, but theoretically you require a multi-employer CANADA RAIC.
Re: RAIC Passes
whats the difference between a CANADA PASS vs Aircrew Pass?
are they essentially the same?
Re: RAIC Passes
Apples and oranges, it can be both at the same time. A CANADA RAIC is for multiple airports (but still issued by a single airport). An Air Crew RAIC simply designates a RAIC holder as Air Crew.SpeedChecks wrote: ↑Sun Dec 08, 2019 11:18 am whats the difference between a CANADA PASS vs Aircrew Pass?
Re: RAIC Passes
Multi Employer Canada Pass does indeed exist. Looks like a Canada Pass, says " multi-employer" across the bottom.
