Dauntless Aviation Inrat prep Software
Has anyone used the above mentioned app to prepare for the inrat? if so, is it a accurate representation of the actual exam?
Re: Dauntless Aviation Inrat prep Software
I used it exclusively, and did well. Yes I'd say it was reasonably representative of the actual exam questions. Although, looking back, unless you don't have the 750hrs required, just go straight to the ATPL exams and get it over with.
I used it several years ago and really liked it. Once you buy it you can keep updating it at no cost so I still occasionally use it for review.
INRAT can not be replaced by the As, cargocowboy is probably thinking about IATRA.
Ah yes, my mistake, I was thinking of the IATRA. But I did use dauntless for the INRAT, and it was good. Good luck.
I don’t know how you guys liked it...
I found the questions were very different from the actual INRAT, for example the app asks stuff about ops spec which isn’t on the exam.
