Who Cares About an Antinov, When You Can Have a MI-26...
- Rank Moderator
Now this is a serious machine.
Same cargo capicty as a C-130, and will lift 20 tonnes(40,000lbs) on the hook, all while blowing down a forest near you... for $35,000/hr
Be neat to see pictures of the shovel they're lifting to Diavik...
- Flying Low
That's perfect...no need to clear an area. Just hover and the area clears itself!
- LostinRotation
I see the seats are lined with paper for when the pilot craps himself if something goes wrong. A machine that big with a 20 tonne anchor pulling his ass to the ground. What a handfull that thing must be !
-=0=LiR=0=-
-=0=LiR=0=-
Sometimes I think it's a shame when I get feelin' better when I'm feelin no pain.
- fingersmac
- fingersmac
- rotorhead350
I have got a friend of mine that has something like 1000-1500 hours as captain on the things. He was just recently lured over to Airborne Energy Solutions to take part in their projects with it as a support pilot on a 212. With the understanding that he will become company check pilot in a year or so as mandated by Transport. He has always said it is a truly amazing helicopter................rh350
From Whitehorse Star Online (via Vertical Magazine Daily News Online)
http://www.whitehorsestar.com/auth.php?r=42604
Giant chopper costs $20,000 hourly to rent
By . Tobin
The world’s largest helicopter, en route from southern Russia to Yellowknife, stopped in Whitehorse on Friday evening to refuel before departing Saturday morning.
Tony Hunley of Alberta’s Airborne Energy Solutions explained today the MI-26 Halo will be used to resupply and service the mining industry north of Yellowknife which is normally serviced by winter roads.
“We expect to be in the Yellowknife area for about 30 days,” Hunley said.
He said his company has leased the helicopter for a year as a trial period to work in the oil and gas industry in western Canada and the Northwest Territories.
The initiative has been in the works for three years. If using the MI-26 to service the industry proves to be viable, it will be staying on longer, Hunley said.
He said drill rigs are now being designed and built to specifications that will take advantage of the MI-26’s capabilities.
Once finished in Yellowknife, the helicopter will be based out of Whitecourt, Alta., the home of Airborne Energy.
The chopper burns 3,000 litres of fuel an hour, and charges out at more than $20,000 an hour.
Its cruising speed is 255 kilometres per hour (183 mph), and it can lift a maximum 20,000 kilograms (44,000 pounds).
Hunley said when you consider there is a relatively small time frame in the year for oil and gas exploration, given restrictions on winter-road access, it makes economic sense to have a helicopter that can move this type of heavy gear all year long.
Some areas, he said, are not even accessible by winter road.
Hunley said part of the planning for the MI-26 program involved providing two captains with the necessary language preparation and Canadian flight regulations to permit them to obtain their Canadian flight certifications.
There are five members of the flight crew – two pilots, a navigator, flight engineer and load master. Also onboard Friday was a five-member maintenance crew.
With two captains trained to Canadian standards, there is the ability to establish a shift rotation, Hunley said.
The MI-26 departed from Rostov-na-Donu in southern Russia, stopped in Moscow to refuel, and gassed up in northern Siberia before flying across the Bering Strait to refuel in Anchorage, where it lifted off Friday morning.
The Russian-built chopper measures 34 metres long, eight metres in width and eight metres in height.
Its eight main rotor blades measure 40 metres in diametre when turning, and its tail rotor measures 7.6 metres in diameter.
By . Tobin
- low n over
