The "APU" was a very small gasoline powered generator used to assist the
batteries during engine starts. All the Canso's I flew had them.
He probably just forgot to shut it down after he got the engines going.
FOUND ON THE WEB...............
My brother-in-law, Bob Vanderveen, was one of the few "lucky" people have
gone on that expedition and the 1995 one.
He nearly died in the tragic fire that consumed the B-29. Perhaps the one
item which saddened me the most about many of the posts was the reoccurring
theme that the expeditions were poorly planned. Nothing can be further from the truth.
They didn't just hop over to Greenland one day after having a cold one on the back
porch in California with the thought of simply dumping a bit of fuel into the Kee Bird,
kicking over the engines and flying the bird back to the States. Come on, just think a
moment about the logistics of the expeditions for just a moment. (By the way, I
don't purport to be an expert as to what happened during the trips nor am I a real
aviationenthusiast)
- They had to find, buy, rebuild and test four B-29 carbureted engines.
They did this work in Ramona, California many, many months before
the summer 1994 trip. Bob and a number of others spent many long
hours for months attending to those engines. Spare parts are not in
plentiful supply for B-29s.
- They had to build and scrounge up an incredible amount of parts,
supplies and tools to take back with them to Greenland, including a
crane, bulldozer, propellers, cables, tires, bomb-bay doors, food for
6-8 weeks...
- They had to plan with Thule Air Force Base to allow them use the base
for part of their operations.
- Only one barge per year goes between North American and Thule.
The four rebuild engines along with a lot of the other parts had to
get on it. This stuff had to get loaded on trucks and carted to the
east coast in time for the barge departure. This had to be done
months before they would get to Greenland in 1994.
It should go with out saying that this required a lot of planning on
Darryl Greenamyer's part.
As to the donation argument, even after all the press about the 1994
exhibition, they couldn't even find even one donor to give them the
necessary clothing for the much colder 1995 mission. Each member had
to buy their own equipment.
With that said, here's a little from what my brother-in-law told me
about the last mission. (It's been awhile since he told me this story,
so some of the info might not be completely accurate. Also, Bob hasn't
wanted to talk about it too much.)
Bob was one of the four people on the Kee Bird during its last run.
He was stationed in the rear of the plane. While the plane was moving
down the bumpy, icy runway on top of the frozen lake, a lot of dust
swelled up inside the plane and in the rear cabin from the years of
dirt that accumulated in every nook-and-cranny of the plane. He quickly
realized that he had forgotten to wear his goggles and decided to go to
the middle of the plane to search for them. That's when he discovered the
APU was on fire. When he went to get the goggles, he had to leave the
headset for the intercom to the cockpit in the rear cabin. Once
he saw the fire, he knew he had to alert Darryl, Al Hansen and Thad
Dulin in the cockpit. In a matter of seconds the already dust filled
rear part of the plane became densely filled with thick, black smoke.
Bob had to feel his way back to the rear cabin, scrounge around for the
headset and with what little breath he had left, yell FIRE into mic.
He then had to run back through the smoke, breathing in a number of lung
numbing mouthfuls of the acrid smoke, and tumble out through the bomb-bay
doors onto the harsh ice. Meanwhile, as Darryl, Hansen and Dulin were
scrambling to try to get out of the cockpit hatch, one of them discovered
that their quick-release seat buckles didn't want to release. Another was
quick enough to find a rod and helped to pry the buckle open. Within
moments after Bob popped out the plane, the tail fell off and a few more
moments later after the cockpit crew jumped to safety, the fuselage was
fully involved. The plane continued to burn for hours.
From what it sounds to me, fire extinguishers would have had no effect.
By the time Bob saw the fire, it was already far too advanced to do
anything. Perhaps if they had a firefighter, in full turnout gear and
wearing a SCBA in front of the APU, they might have had a chance...
From what I understand, nothing was worth salvaging after the fire.
My brother-in-law had nearly $10,000 worth of tools, gear and camera
equipment burn up on the plane. He was sleeping on board the plane at
night since his tent somehow didn't arrive in Greenland and so he had
everything in the plane. He completely volunteered on the exhibitions,
while my sister had to work double duty at their Ramona Cafe Restaurant
in Ramona, California while worrying about her husband's safety in
Greenland.
I hope this gives a bit more insight as to what happened during the Kee
Bird recovery mission and that being an armchair coach in a warm 70
degree home makes it easy to criticize the work of a few brave people
out in a desolate place a few hundred miles from the north pole and in
sub-zero degree weather trying to recover a 43-ton plane. Take it apart,
yeah right. I'm happy that there are still a few people willing to take on
incredible risks.
A few other things:
1. Darryl received permission from Denmark to extract the plane. It was
not there simply for the taking.
2. The location of the plane was well known. The B-29 was supposed to
have been destroyed right after the plane crash landed and its
crew rescued in 1947, but for some reason the orders were never
carried out. If they were, all of this would have been a mute point.
3. The Caribou wasn't chosen for its looks. It had to be able to
carry a large payload and land and take-off on a short (about 1500')
loose dirt/muddy runway.
4. The original engines, which are the late model, fuel-injected versions,
and removed during the 1994 effort, are (I believe) in California. So,
yes, something from the original bird is still around.
Regards,
Stefan Steiner
stefans@concentric.net (soon to be cancelled: ssteiner@netcom.com)
http://www.concentric.net/~stefans |
