Armstrong crash?
- thecaptain
Armstrong crash?
Listening to 67 all day today... some rescue 323 flying around and pulling folks out of a crash? GETK I think was the reg. Anyone know what happened, everyone ok? I hope everyone is alright.
AEROMONKEY
CADORS Number: 2007O2511 Reporting Region: Ontario
Occurrence InformationOccurrence Type: Incident Occurrence Date: 2007/11/30
Occurrence Time: 1845 Z Day Or Night: day-time
Fatalities: 0 Injuries: 0
Canadian Aerodrome ID: Aerodrome Name:
Occurrence Location: vicinity of Armstrong Province: Ontario
Country: CANADA World Area: North America
Reported By: NAV CANADA AOR Number:
TSB Class Of Investigation: TSB Occurrence No.:
Event InformationMissing aircraft
Aircraft InformationFlight #:
Aircraft Category: Aeroplane Country of Registration: CANADA
Make: AERO COMMANDER Model: 500B
Year Built: 1961 Amateur Built: No
Engine Make: AVCO LYCOMING Engine Model: IO-540-B1A5
Engine Type: Reciprocating Gear Type: Land
Phase of Flight: Unknown Damage: Unknown
Owner: HICKS & LAWRENCE LIMITED Operator: HICKS & LAWRENCE LIMITED (542)
Operator Type: Commercial
Detail InformationUser Name: Donaldson, John
Date: 2007/11/30
Further Action Required: Yes
O.P.I.: System Safety
Narrative: The Hicks & Lawrence Limited Aero Commander 500 aircraft was on a [type of flight unknown] flight from [origin unknown] to [destination unknown]. The operator advised NAV CANADA staff that the aircraft was missing. An ELT signal was picked up in the Armstrong area. J.R.C.C. Trenton staff advised. Three (3) S.O.B.
Date: 2007/11/30
flyincanuck
water wings
http://www.ctv.ca/servlet/ArticleNews/s ... hub=Canada
no details, really, just the over all good ending.
- LostinRotation
Glad to hear all are going to be okay, hicks was an awesome place to work with great people.
http://www.tbsource.com/Localnews/index.asp?cid=102453
AEROMONKEY
They, are three very lucky lads. Anytime you "dead stick" into the bush, and get away with it, you are one lucky dude, indeed. Very good outcome to what, so easily could have been a very sad day. Slap on the back to the rescue unit for their quick action. Finding a downed aircraft in the bush, and getting everybody out in one piece, the same day, is nothing short of a miracle!
EatSleepFly
- Cat Driver
Clunk....I lost both engines on a Navajo one night IFR and it was only pure luck I found a hole over Brandon to spiral down through...the cause was ice crystals in the fuel lines gradually blocked the fuel lines lost the right engine and about fifteen minutes later the left engine.
Once again an airplane that had been stored in a hangar with water in the fuel system.....and you can't drain it at below freezing temps.
clunckdriver wrote:EatSleepFly, you asked a question so I will answer you, nothing I may say in any way refers to this crash. {1} Aircraft was used for fire season , has sat in VERY cold and fluctuating temps for some time, could have had a crap load of water in solid form in the tanks, the best way to get this out in low temps is put in some Methel Hydrate and wait 12 hours and drain till its clear fuel.{2} Many aircraft flown in Summer only dont have the breather tubes drilled or insulated, if not drilled and you get ice in the breather you will blow the prop seals and down you go.{3} If an aircraft has single grade Summer oil it may get "coring" in the oil cooler, many do not have a by pass system, so again no lube and down you go again.{4}Prop seals and other seals and gaskets that have been cold soaked for some time without a long pre heat period have a distressing habit of letting go. Im sure many of the high time piston pilots on this forum can come up with a lot more resons as to why a twin can become a glider real fast!
BS BS and more BS
I will wait to hear from my friends what happened....
I-S-M,,,, I thank the lord that fate has not been your hunter...
Not speculating in any way what happenned in this incident, however....
AC500's have effectively only one gas tank. There are several interconnected bladder tanks, but they all lead into the same sump, and there is no way to cross feed. If you get a leak, or a serious blockage you're kinda SOL.
Doesn't happen very often, but it can.
Northern Skies
Clunckdriver knows of what he speaks..{3} If an aircraft has single grade Summer oil it may get "coring" in the oil cooler, many do not have a by pass system, so again no lube and down you go again.
Time for the newbies to learn about the "pour point" of oil ... if
it gets colder than that (ie in the cooler) it congeals.
In the winter, you are foolish not to run a multi-grade oil in
the winter. In particular, Aeroshell 15w50 has a pour point
of -42C. Straight grade oils will congeal at higher temps
than that.
http://www.shell.com/static//ca-en/down ... iation.pdf
Northern Skies
I found out, It was my friend who was injured.
He is one of the most professional, safe pilots I know. I heard that those involved have nothing but praise for the way he handled the situation.
I am very glad to hear how everything turned out. A double engine failure in the bush in winter is not something I would wish pon my worst enemy.
EatSleepFly, you are such a dickhead. Were you there? Do you know what happened? It's not like these pilots wanted to crash... it's really easy to place blame and say "why did you do this" or "why didn't you do that" after the fact. Until you're in that situation, STFU.EatSleepFly wrote:how do you lose BOTH engines other than fuel exhaustion, and still how do you NOT have time to make a mayday call before you go down in the bush.
Did it ever occur to you that maybe they did make a Mayday call but being north of Armstrong, Ontario no one could here it. Of course if your from the Toronto area you would have a very hard time comprehending this so why not just keep your lame comments to yourself!! The guys involved are all personal friends of mine as well as coworkers and I can assure you that professionalism is alive and well with this group!!
Just very glad to hear such a great outcome!! Looking forward to having a beer with them real soon!
