Canadian North
Moderators: lilfssister, North Shore, ahramin, sky's the limit, sepia, Sulako, I WAS Birddog
ODA
Canadian North
Post by ODA »
Just heard Empress 445 coming into Yelloknife with an engine out!
Hope everyone's okay
TAT
Post by TAT »
I was delayed because they shut down the airport to allow them to come in. Apparently they had a fire on the #2 engine and shut it down. Took them a while because they had to dump fuel. :idea:
Brantford Beech Boy
Post by Brantford Beech Boy »
Dump fuel in 737........ me thinks not.
or wuz it a Fokker?
BBB
SkyKing
Post by SkyKing »
445 is out of calgary and then edmonton usually right?
and it's more often the fokker i think, although both aircraft do the route.
so i would assume it was the f-28.
Trent Steel
Post by Trent Steel »
It was a 737.
iflynkd
Post by iflynkd »
Neither has fuel dumping ability...
jetpilot
Post by jetpilot »
A B737-200 cant dump fuel, two choice here! hold or land flap 5 high speed
happen to me before! not nice!
cheers
Arctic Icarus
Post by Arctic Icarus »
A one engine inoperative landing with a 737 is performed with flap 15. You do the approach at Vref 15 plus 5 knots.
Manko
Post by Manko »
jetpilot,
when you say high speed...usually how high is it? and are you sure it is flap 5 on a single engine approach? i remember asking some wj pilots one time and i was told flap 15 for s/e approach....just curious..that's all
cheers :D
Arctic Icarus
You are right. For a single engine approach, it is a flap 15 landing. The speed is a fair bit faster than say a flap 30 or 40 landing but it also depends on your weight. Generally the Vref speeds for a flap 30 or 40 landing are about 110 to 135knots for weights of 75 000 to 105 000lbs. Landing at flap 15 gives a Vref of between 119 to 150knots for weights of 75 000 to 115 000lbs (higher weights allowed for flap 15 because flap 30/40 have a limits of 108 000lbs).
