"Commercial pilots need stall recovery experience" article
Another informative article in the December 16, 2013 Aviation Week & Space Technology (a good issue) opines that Commercial pilots need stall recovery experience. It describes a new FAA rule requiring airlines to get pilots doing full stalls. Halleluiah! Of course, this was driven by the apparently miserably failed stall handling of the 2009 Colgan Air Buffalo Dash 8 crash.
The article reports that "pilots....are finding themselves in stalled aircraft without the proper reflexes to recover.". I fear that I know why, but there is no excuse. Aircraft are designed so they can be stalled and safely recovered, if you do it neatly.
The requirement, in part:
Sec. 25.203
Stall characteristics.
(a) It must be possible to produce and to correct roll and yaw by unreversed use of the aileron and rudder controls, up to the time the airplane is stalled. No abnormal nose-up pitching may occur. The longitudinal control force must be positive up to and throughout the stall. In addition, it must be possible to promptly prevent stalling and to recover from a stall by normal use of the controls.
Now I concede that some company policies prohibit stalls, and this has been a problem for me during flight tests with a company pilot. I even had one Chief Pilot tell me that a stall was an in flight emergency. I asserted that approached properly, it did not need to be. We did not agree about this.
To me, being in the back, being flown by a pilot who does not have a sharp instinct to recover a stall by feel, would be like riding in a bus, driven by a driver who had no instinct to swerve around an obstacle in front.
The article closes by saying ".... the FAA requires pilots to experience full stalls and recoveries.... It is reasonable and sound".
It's not only reasonable and sound, its vital! Whatever you fly, I would like to think that you find a good, clear calm day, take it up high, do a "Hasel" check, get the ball in the middle, and wings level, and stall it a few times - or get training and do it!
Sec. 25.203
Re: "Commercial pilots need stall recovery experience" artic
I have not read this article. TC had a Advisory Circular come out in November titled: "Prevention & Recovery from Aeroplane Stalls"
http://www.tc.gc.ca/eng/civilaviation/o ... -1793.html
Air France pilots, pick up the white courtesy phone.....
No no, with the new MPL they have a good discussion and session in the sim followed by a pat on the back, that's plenty.
I fear that you are correct. I couldn't agree more that pilots should receive stall recovery training.PilotDAR wrote: .... I fear that I know why, but there is no excuse.
Many trainers feel a omplete stall is an uncontrolled maneuver whereas the approach to a stall and recovery at the first indication, be it the buffett or the stall warning, is a controlled maneuver. I thought that all airline pilots flying large airplanes or jets have to be trained in the simulator and do the sim instructors know how to teach approach to stall recovery?
The article makes reference to sims being used for big jet training, but their characteristics not being representative into the stall, and needing some rejigging to be appropriate for training in that realm. I admit it... I never stalled the DC-8-63 sim back in the day, I was just happy to be flying it at all!
A stall is a stall is a stall. Send them up in a bloody Citabria!
I'm with Brown Bear. Just get them out there and comfortable in the stall. Before you say we don't want them to be comfortable, let me say that I think the problems in some of the recent stall accidents may be as much about pilots freezing on the controls due to panic as not indentifying that they are in a stall.
Agreed! I wish TC would see it this way as well. Instead they feel stalling a 767 and a Pitts special are completely different, so therefore a useless training exercise for the new and improved MPL pilot! Why bother with straight and level flight or any other basic training skills? Just put a chair in front of a window and make them sit for 6 hours!Brown Bear wrote:A stall is a stall is a stall. Send them up in a bloody Citabria!
I'm reasonably sure that a decent amount of somewhat inaccurate sim training would still have been enough to keep the poor bugger in Air France from pulling back in a stall from flight levels all the way down to a thousand feet or so.PilotDAR wrote:Air France pilots, pick up the white courtesy phone.....
- Colonel Sanders
I was doing some tailwheel training/refresher with
a pretty experienced pilot the other day. We worked
through the "rolls around a point" and the "falling leaf"
and then got into the circuit and started working the
tailwheel landings, which demand precision in alignment
at touchdown.
The light bulb went on, and he said, "This really improves
your instrument flying, too, doesn't it?"
Sure does.
at touchdown.
Sure does.
In the otherwise thorough investigations of AA587 and AF447, it somehow transpired that a similarly loaded airframe was not exposed to the accident conditions.
Now I'm not at all suggesting that all the crew mistakes be repeated all the way to losing another airframe, but it would be highly worth while to understand the aircraft approaching the accident situation.
We do not have a validated in the airframe recovery method from:
- wake encounter in an A300
- high altitude stall in those various laws without stall protection in the A330
Stalls in a 767, Cessna 150, Citabria, etc., all have two things in common. If you pull back on the stick, the houses get smaller. If you continue to pull back on the stick, the houses get larger again. And yes, this undeniable fact of life can be taught in a J3.
D
D
Upset/Stall is a big issue -- companies try and train in the sim but the total irony is that it's done with the motion turned off because the sim would jump off it's jacks -- so it turns into a video game -- I'm not entirely up to date on this but last time I looked into it there were only about 3 simulators in the world that would give you the full meal deal in a jet upset -- they were active in motion and simulated all the g-forces etc associated -- so the solution -- don't do anything -- carry on as before -- until you remove the pilot completely there will always be a need for reasonable stick and rudder skills --
I was in a symposium and an expert stood up front and made the statement that c-fit in 705/121 in north america was under control and had been replaced by stick and rudder skills because of automation and how it was expanding across the entire aviation world even down to the basic training level. Pass the aileron drag
ACTPA
ACTPA
In our company, we train initial hires on all allowed stall scenarios, and revisit them on the annual check ride, noting indications, airspeeds, and recovery requirements and variations. On each type to be flown. it's one of the more discussed subjects around the table and appreciated comfort the knowledge / skill brings.
Doesn't everybody?
Doesn't everybody?
Frankly, I feel it may be as basic as recognizing something is amiss, and having the SA to realize that what you're doing just isn't working. In the Air France scenario, I don't want to over simplify it, but cruise deck angle, paired with cruise N1, would have got the job done. It doesn't need to be pretty. It does need to be recognized as a stall. Jet upset is outside my area of expertise, but it obviously should be recognized for what it is, and quickly.
Toss all you captains into a Citabria for a couple of hours. Might solve some issues.....and, it would be cheap!
A stall is a stall, but I think it's the recovery they are getting at. A high lift wing like a Citabria all you really have to do is release the back pressure. A jet at altitude you have to pitch down significantly to break the stall or you will ride it all the way down. Apparently some of the people that tried this where quite surprised how far they had to push. Not that I have any experiences with this, but that was how it was explained to me to by someone with far more experience.
That's great to read. These "all allowed stall scenarios" would include:?we train initial hires on all allowed stall scenarios
"Stall demonstration.
(a) Stalls must be shown in straight flight and in 30 degree banked turns with--
(1) Power off; and
[(2) The power necessary to maintain level flight at 1.5 VSR1 (where VSR1 corresponds to the reference stall at maximum landing weight with flaps in the approach position and the landing gear retracted).]
(b) In each condition required by paragraph (a) of this section, it must be possible to meet the applicable requirements of Sec. 25.203 with--
(1) Flaps, landing gear, and deceleration devices in any likely combination of positions approved for operation;
(2) Representative weights within the range for which certification is requested;
(3) The most adverse center of gravity for recovery...."
This are all allowed, and required, during certification testing. I find that some pilots have not recently (or ever) entered a stall with a deliberate bank angle, particularly carrying power.
So operators do not "allow" some configurations of stall entry, and this is a disadvantage to confidence building and skill maintenance for pilots.
Hey DAR,
yes, we do banked climbing / descending stalls. The "limitations" are those in the aircraft manual. I've checked with a few other training captains and they tell me that often the first indication limit is applied which I agree is good for the operation of the specific aircraft, but not the best for the skill set for the event. Some time in a machine capable of more adventurous flying would likely be of benefit to everyone, and a lot of fun.
g
g
